Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Flyback board for RCAd52w20
Replaced cap replaced transistor now nothing used to have green light blink now nothing looking for flyback board any sugestions have lots of power to board stumped
    Sergeant:
    Champion:
  • 258 Answers
A bad flyback will inhibit the protection circuit. This sounds like what's happening.
Posted on Aug 18, 2008
Audio and picture go dead red light blinks 7 times
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
Jan 24, 2011 | Sony FD Trinitron KD-36XS955 36" TV
What does blinking red light mean on power button and how do we fix it to turn the tv on?
sounds like the flyback,to replace it is very dangerous, if you not fimilar with high voltage 20 to 30,000 volts, it can kill you, be careful. you have to make sure the tv is unpluged from outlet,use a voltage probe or rubber insulated flathead screw driver made with wire and allagator clips. carefuly ground one end of clip to the shield or strap or a good ground from tv. run it under the cap on the picture tubeto discharge it,then turn cap counter clockwise to pull cap off. then turn the board upside down , use a solder ****** and solder iron to remove the flyback. get the # off the flyback,oder orignal or sub.then resolder.
Feb 14, 2010 | Toshiba 32A33 32" TV
No pict. power button blinks
Chances are you have a bad flyback and two bad electrolytic caps and a retrace cap gone bad. At its best you may have bad grounds under the H.O.T. And that would be under this transistor next to the 100 ohm half watt resistor a coil.Unsolder this coil clean the board contact and replace this coil!
Dec 19, 2009 | RCA F36650 36" TV
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
RCAD52W20 wont power up.
usually its recomended that CP150 be replaced with the Flyback. You can get the replacement flyback number 259296 and CP150 at the following link with free step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w20 will not come on
sounds likje the flyback those sets are famous for the flybacks needing replacement.They dont always blink 3 times when the flyback fails, often they justrefuse to power up.
Sep 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV WILL NOT COME ON LIGHT BLINKS 3X
Thats the error could for a bad flyback. You can get a replacement flyback at the following link with free tech support to take you through the steps to replace it. You need flyback number 259296.
Heres the link
Aug 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA, rear prjetion, 46" tv,no power, ticking sound
Ticking is usually related to the horizontal output and the flyback with the flyback being more suspect. If you need more assistance please let me know
May 13, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
