Question about Zenith DVP615 Portable DVD Player
How to connect dvd to tv
When trying to connect dvd player to tv, i get sound but no picture, tried several ways and tv's but no luck. The main tv i'm trying ,connects in the front and has input (front) for connection. Rca connector is red,white and yellow on one end and black and yellow on the other. What am i doing wrong
Obviously you already already have the correct cable! However, the audio inputs to the TV set are RED and WHITE, not both white. You could get sound if only one was plugged in properly and no picture if the yellow plug was mistakenly put into the other audio input. Just make sure you have the yellow plug to TV's video input. If you get no video then, maybe you have a bad cable for video only. Test it out on another TV or in a different video input on the same TV.
Posted on May 30, 2009
    President:
  • 814 Answers
You need to use the supplied cable from zenith to make the correct connections. The cable is a three in one cable. The dvd side of the cable is a single connection. This connection go's into the a/v out next to the power jack input. The other end of the cable goes into the television. Yellow cable into the video input and the two white cables in to the audio inputs. this is the correct way to connnect the dvd to the television.You can get technical support from Zenith at this telephone number. 1-800243-4994. I hope this information helps you with your problem.
Buy a special cable
Posted on Sep 17, 2008
SOURCE:
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Sound but no picture dvd hr750
did you tried to replace the cable or tried using different tv unit just to isolate first where the main cause if the dvd player itself or with in the tv.how about using other component input and port have you been already tried.
Jun 29, 2012 | Televison & Video
No sound from dvd player(picture is fine).works on another tv
Try another way of hooking the Player up to the TV, you have several options here to do that on modern TV's
Dec 29, 2011 | LG Televison & Video
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Zenith DVP615 Portable DVD Player Logo
345 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
