Question about Canon PIXMA MP780 All-In-One InkJet Printer
Distinct ring function for fax?
I set my machine to fax only and it is still picking up all incoming calls. My fax line has a "distinct ring" feature through the phone company and I need to set it on this machine. Do you know how to do this?
  • dzucca Aug 13, 2008
    Great!!! Thanks so much for your help ....
  • 928 Answers
Setting The Receive Mode
  1. Press <FAX>, then press <Menu>.
  2. Press <OK>.
  3. Use [<]or [>] to select the receive mode.
  4. Press <OK>.
Posted on Aug 13, 2008
  • Thomas Lim
    Thomas Lim Aug 13, 2008
    Receiving with a DRPD (Distinctive Ring Pattern Detection) service: DRPD
    Choose this mode if:
    you only have one telephone line for both fax and telephone use.
    you want to receive faxes automatically as well as voice calls.
    you have subscribed to a DRPD (Distinctive Ring Pattern Detection) service with your
    telephone company. This service assigns two or more telephone numbers with distinctive ring patterns to a single telephone line, allowing you to have both a fax number(s) and a telephone number(s) using only one telephone line. Your machine will automatically monitor incoming calls and based on the ring pattern, will let you know if the call is a fax or voice call. Contact your telephone company for more information on this service.
    You will need to:
    set [DRPD].
    connect a telephone to your machine .
    When you receive a fax call: The machine will ring according to the ring pattern you have
    chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have
    chosen. Pick up the handset to answer the call.
    Setting up DRPD
    Follow these instructions:
    Press the button.
    Select [DRPD] for the receive mode.
    Press the
    button.
    Use [< ] or [> ] to select [RX SETTINGS].
    Press .
    Use [< ] or [> ] to select [DRPD:SELECT FAX].
    Press .
    Use [< ] or [> ] to select the pattern that matches the pattern assigned by the telephone company.
    Press .
    Press .
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
Fax is not coming through.
Jul 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Distinct ring feature
I see youve seen the solution already. Glad to know it was fixed.
Aug 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
71 people viewed this question
old marine
old marine
