Question about Motorola Mobility W375 Cellular Phone
WS375 Motorolla Mobil
Hi I'm trying to connect the above phone to my computer through USB but when i connect to my usb port, its asking me to install the software. Where can i get the software from?
    Scholar:
  • 103 Answers
You do not need software for USB file transfer.
If you are with Net10, the reason is doesn't work is because Net10 have switched off USB connectivity.
If you are not with Net10, connect your phone with the flip open, then go to My Computer and you should see MS Device listed alongside you C, D, E (etc) drives. Click it, and you're into your phone's tiny storage area.
Posted on Aug 19, 2008
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
I bought a new Motorola rokr EM325 - it has USB connection to transfer music files - computer recognizes removable disk (F:) but will not allow me to open or drop files into it (comes up with I/O...
Make sure that the USB drivers for the systems are actually loaded and you are not running on the Default Windows drivers. To check this one out you'll need to look in Device Manager to see if there are any Listed USB Ports shown as not working or needing an updated driver.
With these propriety systems they quite often do not always install the correct drivers for USB and LAN ports and this can cause quite a few problems.
Oct 30, 2008 | Motorola Lands Phones
With nokia 6110 naviagtor connected via usb to my pc, route 66 gives me an error message saying "device not connected" with <quit> being the only option. I've re-booted the PC (windows 2000...
Hi...
are you a technician? because maybe you have disconnected terminal in USB Port in your CP! make sure that the connection is Connected to PCB.
Apr 20, 2008 | Cell Phones
I can not able to connect my phone with pc suite so please give me assisitan
The solution provided below will definately be of great help to you
1.Locate the mini-USB port on your phone. This is usually found on the left or right side of the phone, so look there before checking the top or bottom
2.
Use a standard size mini-USB to connect the phone to the computer. Plug the end of the small cord into the phone's mini-USB port and then plug the big end into a standard-size USB port on your computer.
3.
Install drivers which are locatrd on the pc suite of your phone Once your phone is connected physically, a software link must also be made. Your computer will not automatically recognize your phone, and a window will pop up asking if you want to install some drivers. Click the "yes" or "OK" button to continue.
4.
A status window will pop up once your OS has found suitable drivers. Once the status window fills up, your computer will be ready to interact with your phone. The phone should now be charging. Check the phone screen to make sure.
5.
Install any relevant software. Branded smartphones from Palm, BlackBerry and Motorolla all have specific software that comes bundled with the phones. Once the software is installed, you can launch it and interact further with your phone
Good luck!!
Aug 04, 2010 | Nokia N72 Cellular Phone
USB DRIVER OF A CHINESE MOBILE PHONE NAMED "SIGMATEL T99"
dear ravikant,
In the phone's setting please find disable charging when connect via usb.
Regards
Jan 19, 2009 | Handmark Software MobileLists (950142) for...
'Communication Not Available' message when printer cable connect
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Nov 18, 2008 | Lexmark X2250 All-In-One InkJet Printer
Can't connect to usb port
Hi all! I had the exact same problem - the remote recognized the USB connection but my computer (MacBook with Leopard) / Logitech software did not.  I took the advice of  bfuzcsvxvgk  and it worked like a charm.  I wasn't sure what the "Home" folder that he or she referred was, so instead I entered "Logitech" into the Spotlight finder and the Logitech folder came up.  There was only one file (usblancognac.cmd) in the folder and I deleted it. After that I reopened the Harmony Remote software and it opened! THANK YOU THANK YOU THANK YOU!  Hope this helps if you are having problems!
Sep 25, 2008 | Logitech Harmony One Advanced Universal...
Sigmatel s4
hi there!
you first have to install the driver software for your cell phone...
as in windows Xp it shows MT6225...
after installing the usb drivers when you connect your cell with usb cable on the cell phone a menu will appear...
- Mass Storage
- Com Port
- Camera
you have to select the mass storage option then your cell will show it self as a usb disk in PC... and if you have Memory card then there will be two usb drives appear in your My Computer Window....
you just have to copy paste your files...
Aug 29, 2008 | Handmark Software MobileLists (950142) for...
Hi just purchased Samsung j700 mobile phone. Trying to connect to PC with USB - seem unable to get driver to work - even the one on the disk?
that's the link with driver for samsung SGH J700 works perfectly with my phone
http://www.samsung.com/au/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=megapixelphone&model_nm=SGH-J700&disp_nm=SAMSUNG%20J700&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01011800
kisses all :*
May 18, 2008 | Cell Phones
Lexmark 3100 printer
hi
U first install the printer software which is given by the printers and install it. after that u connect the usb port it will automatically ask you whether u connect and let u install the driver for it
Feb 21, 2008 | Office Equipment & Supplies
Motorola Mobility W375 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
