Question about Creative Labs Zen Digital Media Player
Two problems. l. battery shows down but when on charger the little green light thing comes on with a "lightening flash" cutting it. second problem, unable to play one song after another without pressing shortcut, is there a way to bypass this. THANK YOU.
    Problem Solver:
  • 24 Answers
Its supposed to do that thing when it is charging ...(that means its charging)
go on settings then you have to go to replay song
Posted on Oct 17, 2008
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
When turn on my laptop,the doesnt respond and the lit on swicth bouton goes off after 30 sec.
Power issue. Assuming that the charger is working ok, the battery is showing as being servicable and the charger port is not loose or damaged, the fault lies with the motherboard.Before blaming the motherboard, try these first
Check that the charger light is not flashing green, indicates that power is not reaching the motherboard.
try removing the battery and ac power, pressing the on / off switch for 30 seconds and then reconnecting the ac charger, see if it boots. if it does, refit battery ( this clears the cmos)
Check also that the cut off switch ( just under the lid bottom) is not fouling and sticking down, if necessary, free it off.
Jan 28, 2011 | Dell Latitude D600 Notebook
My laptop, dell inspiron 1800, cuts on but after a few seconds cuts back off. it lights up but shuts back off
A few things to check:
1.) Check the battery is charged and the charger is supplying the right voltage and the power jack is tight in the laptop DC port. Check that the charger (on charger) light is steady green, not flashing.
2.) Remove battery and try to boot on AC Power, if this works, either the battery is not charging (dead battery) or the charging circuit in the laptop is damaged.
3.) Remove Ram modules oner at a time, see if it boots with one module in, if it does, then issue is with the ram
4.) Examine the cooling vents, try blowing them to see if any dust is released, hoover them as best you can, if this cures the problem (and it will be a temporary fix), get the laptop stripped down and give it a proper clean around the processor and fan areas. (overheating issue)
If it does not help, then Its looking like your motherboard has developed a fault through maybe overheating
Jan 20, 2011 | Dell Computers & Internet
Anomalous charging behaviour :- a) plug in discharged battery b) starts off with the yellow light flashing as usual c) after a very short time the lamp goes off completely - instead of staying on...
Okay, might not be reading this right but here goes. If the camera shows the batteries as full then I'd go with that. The charger will come on for a few seconds even with a freshly charged battery because it take that long for the charger to realize the battery is already full. You can't feed an already full battery, so the charger is shutting off completely. Yes normally the light would stay on and the charger would continue to trickle a charge into it it until it is removed. In your case I think you have those batteries stuffed to the gills so the charger is shutting right down. One of the problems with these batteries is as much as the manufacturers deny it they form a memory. Best thing to do with these rechargeable batteries is drain them right down and then replace with a freshly recharged battery.
Dec 17, 2010 | Nikon MH18a Battery Charger
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Hello! My HP nc6220 notebook will not turn on-if you press the on button an orange lightening bolt flashes. I have it on the charger-
pull the battery out and try again. If it works the battery needs replacing.
just an fyi those are good laptops
Mar 30, 2010 | HP Compaq nc6220 Notebook
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
May 17, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi battery charger
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Nov 16, 2008 | Ryobi Multi-Volt Battery Charger
Creative Labs Zen Digital Media Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
