2002 zenith console television
I do not have a user manual for my console tv and cannot get my tv/vcr or dvd player to play on the television we purchased. There is no aux buttons on the menu screen and yet there are plugins on the back to plug in the video components. We have dish input and I am not sure what is wrong and why i cannot get my items to play dvd or vcr on this television. It does not play even if i turn off the dish and put it on channel 3 or 4. I need a manual or connection help
  • bonz161 Aug 13, 2008
    i actually have 2 remotes but neither wil bring up a auxilary mode for dvd or vcr even though the one does have that option button. I will try as you suggested but if i remember correctly i don't remember seeing a 1/2 line when pressing the up down key. Do i need to have my dish cable go into the vcr combo and then out to the tv instead of the way the current tech hooked it up? the connections are plugged into the same inputs on the rear of the tv as was the old one that we replaced with this one. On a previous tv (in another room) he has the vcr locked in a channel (60) to recieve my programing...I'm afraid that this is the case here and I don't think that will work on this particular tv as the dvd player and vcr are two seperate units. Thanks for your help and input, much appreciated. I await for further advice.
If you lost the remote for a zenith television and want play a movie on an input, use the channel up/down buttons to navigate. Ususally if your on ch 2, press the down button. Line 1/2 will appear on a blackscreen if the device is off. Otherwise, I have had great success using a GE universal remote with my Zenith tv/vcr combo unit. (by the way, I work for the technical support department for my city's local cable company)
Posted on Aug 13, 2008
SOURCE:
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
Zenith KBV713 DVD/ VCR combo
hmmm...do you have the user manual on the DirectTV unit?
May 31, 2008 | Zenith XBV442 DVD Player/VCR
Tip
I need the manual for my Allegro Zenith dvd/vcr or the answer to why I can play...
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems and hook-up problems. The manuals are written for this purpose and they contain useful information.They also contain diagrams of setups, this make it very easy to visualize the set-up procedures. They also contain troubleshooting pages that can help you with minor problems that may occur during your set- up and operation of the unit in the system.The manual also has useful information about the the company and its services. Websites and telephone numbers that you can contact if you are having problems.You should always keep this manual handy for these reasons. I hope this help you to understand the usefulness of the manual and it helps you overcome the minor problem that one always come upon during the initial set-up procedures.
on Jun 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Just got a dvd player, how do i get to play dvd mode?
There are connections on the back of your TV for Audio and Video inputs. You connect the corresponding connections to your DVD player. You then use the TV/VCR SOURCE button on your remote to change to that input. In case you don't have your manual the following web address will take you to a place that will let you download the manual.
http://www.retrevo.com/support/Zenith-C27A24T-TVs-manual/id/277ag102/t/2/
Sep 10, 2009 | Zenith C27A24T 27" TV
DVD disc reads that it is playing, but there is no
what tv connection are you using from the dvd make sure connection are fully pushed in, try another dvd player with the same tv and connections.
Aug 25, 2009 | Zenith XBR616
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Nov 18, 2008 | Zenith B27B40Z 27" TV
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
Ekse
