Question about Singer 7462 Mechanical Sewing Machine
My phaff industrial machine won't pick up thread.
  • Anonymous Mar 15, 2014
    how to thread machine
    how do i thread a phaff 130, machine is 60 yrs. old
    Problem Solver:
  • 5 Answers
Hi my names anela . here a little solution for you to try. take the spool out of its case and place the case on a peice of paper draw around the case, and cut out. then cut out a smaller circle in the middle. and place back into the spoolcase this should help.
if not. then you prob have the needle in the wrong way round turn your needle so the long ridge is facing inwards . thanks angela
Posted on Aug 21, 2008
SOURCE:
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
Needle will not pick up bobbin thread
Try installing a brand new needle. Rethread the machine from the very beginning. The machine could be out of time, ie the needle and hook timing do not match.
Nov 18, 2015 | Singer Sewing Machines
How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
Oct 02, 2015 | PfaFF Sewing Machines
I have juki 1541 industrial machine needle want pick up bobbin thread??
Is your needle inserted correctly? Try taking it out and inserting again. Is your bobbing threaded correctly? Try taking it out and re-threading. You might also try cleaning the bobbin area. The only other think I can think of is that you may have the wrong needle in.
Feb 13, 2015 | Juki DNU-1541 Industrial Walking Foot...
How do I adjust the timing on a pfaff industrial 545?it will not pick up the bobbin thread at all.
This happened to me. Shucks, I had the wrong needle in; it was too short to reach the bobbin thread and pick it up. Installed correct needle (repair man did) and viola. . .
May 15, 2010 | Sewing Machines
I would like to know how to set the timing on my phaff 545 industrial sewing machine
[email protected] and instructions will be attached but remember to put your make and model
Mar 18, 2010 | Sewing Machines
Singer 132K6 industrial machine
Make sure that the thread is under the tension spring then thread it throgh the hole in the spoolcase,push the spoolcase retainer over to hold it in then turn the balance wheel towards you to pick up the thread through the hole in the needle plate, pull both threads back and sew away. I can supply a manual for this machine if you want one.
Robert
Aug 25, 2008 | Sewing Machines
Threading & bobbin won't pick up
Make sure the needle is inserted all the way in with the long groove to the left.
Threading is through 1)the thread guide 2)The tension 3)The take up lever 4) The needle eye (left to right).
Remove the needle plate, thread the machine. Turn the hand wheel and watch the thread in the needle to see if it is above the eye of the needle. If it is, the machine needs to be retimed.
Sewman7
Apr 27, 2008 | Consew 1118-3
Singer 7462 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
