Question about Samsung DLP HL-P5663W 56" TV
Samsung dlp hl-r5667w
Yes check fan number 3 is apearing on my tv after watching it for 2 min then goes away . now the tv is turning off by itself after watching it for about 7 hours thank yu
    Champion:
  • 230 Answers
This Tv make a lot problems with the color wheel and fan thermostat, lamp cool. Need be check the color wheel first. I am suggested dont have nothing on the back cover ( make hot or not ventilation). More information parts at tritronicsinc.com Thank you
Posted on Aug 13, 2008
SOURCE:
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. [email protected]
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
362 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
