Question about GE Model: WCVH6260HWW Kitchen Hood
Installing a driving belt on a GE front loading washer model # WBVH5100HWW
I ordered a driving belt and it looks to be a couple of inches shorter. I'm not sure whether the old belt was stretched so it seemed that much longer. When I ordered the part I was told this was the right belt.
  • Anonymous Jan 03, 2009
    is the belt suppost to be smaller??
  • 770 Answers
What is your model number i can give you the right part number
Posted on Aug 15, 2008
Help i found a broken belt in my ge washing machine wbvh5100hww i bought a new belt and tried to replace it, whenever i try to spin it to see if the belt will stay in place the belt slowly starts to come...
Are the two pulleys lined up with each other? Is the belt tight when installed? Make sure the motor is firmly attached at it's mounting. Is the drum or motor pulley hard to turn by hand? Make sure that neither pulley is wobbling or loose on it's shaft. Hope that some of this helps!
Jul 29, 2010 | General Electric WBVH5100HWW Front Load...
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
Ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 05, 2009 | GE WDSR2080D Top Load Washer
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Front loading ge washer model wbvh5100hww
I had to have repairman out. He said it had a filter in front panel that needed to be cleaned. It was full of hard white stuff, like caliche dirt. He noticed I use Arm & Hammer Detergent and he said that was good, but don't use HE detergents because when they mix with city water, it causes an odor in washer. Thanks- Beth
Sep 14, 2008 | LG WM-2277HW Front Load Washer
You need to put the setting on whites in order for it to take the bleach. Not sure about the fabric softener. I use dryer sheets
Jan 19, 2008 | GE Model: WCVH6260HWW Kitchen Hood
GE Model: WCVH6260HWW Kitchen Hood Logo
693 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
