Question about Danby Refrigerators
Dandy wine cooler dwc283bls-1 has upper code E7. Lower part is fine.
    New Friend:
    Problem Solver:
  • 6 Answers
Temperature sensor open
Posted on Oct 27, 2010
SOURCE:
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
MHello. We have a DWC283BLS-1 wine cooler. I got it from my aunt who had it in storage. The digital numbers on the front keep staying at 83 & 83. Every time I press the buttons to make the number...
It sounds like the Freon leaked down. That always happens when they are stored. Find a community college that has refrigeration classes and maybe they will look at it for you.
Dec 17, 2017 | Danby DWC283BLS Wine Cooler
Temperature in both upper and lower zones will not go lower than 50F. Cooler has 3 bottles of wine. Is there away to recharge with coolant/clean fans...? Thank you
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
Before cleaning the condenser coils, unplug the refrigerator to avoid a shock hazard.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Jul 10, 2011 | Danby DWC283BLS Wine Cooler
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
Jun 02, 2011 | Danby DWC283BLS Wine Cooler
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
E7 Code
Dera grezni
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
With an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You huuum
Aug 20, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
542 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
