Question about Sanyo EM-N107 600 Watts Microwave Oven
Sanyo Microwave Oven EM-P410,p 472, P672 P673 and P841
No longer heats, clock timer works, etc! Son says to toss it, I think its salvageable? Bought new 2001 by previous employer where I was Facilities Mgr. given to me when company downsized in 2004. Was in excellent condition but I think I pushed wrong buttons trying to program? If possible. Do you advise I ship it or not worth it?
Ms Silk
silk_consulting@sbcglobal.net
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
MicrowaveSvc
  • 9086 Answers
SOURCE: Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Posted on Dec 07, 2006
MicrowaveSvc
  • 9086 Answers
SOURCE: Sanyo EM S8000-w microwave range quit..fuse?
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Sanyo Micor/Oven/Grill EMG2553S Clock
You can download your owner's manual here.
Posted on Sep 01, 2008
SOURCE: Set the clock Sanyo EM-V860
I just reset the clock on a Sanyo by pressing "Clock" and "Cancel" at the same time, then "Cancel" then the display went "0", and I typed in the time then pressed "Clock" again.
Posted on Oct 19, 2008
  • 360 Answers
SOURCE: sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Apr 12, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Manual for sanyo microwave oven EM-S3553S
Here it is
http://eu.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-S3553.pdf
Mar 13, 2013 | Microwave Ovens
Aug 29, 2008 | Sanyo EM-G2585W Microwave Oven
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Touch Pad
Touch pads are not the most reliable things. It sounds as though one of the keys is stuck on. There is nothing you can do for this, as there are no user serviceable parts inside, but there are voltages present which are INSTANTLY LETHAL, & may persist even if the unit is unplugged. Check your local thrift stores, as used microwaves are often sold there very cheaply, often as low as $5.
Jul 15, 2007 | Sanyo EM-Z2001S Microwave Oven
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Sanyo EM-N107 600 Watts Microwave Oven Logo
95 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
