Question about Plantronics Explorer 330 Headset
The blue light doesn't turn off
I found my bluetooth plantronic model 330 with the blue light turn off and I have pressed the volume button to turn it off but I doesn't work. what can I do?
  • 3 more comments
  • rrglds46 Sep 17, 2008
    The same thing happened to mine. My bluetooth earpiece was blinking as it usually did when it was on ... about every 10 sec. I tried shutting it off as I usually did by holding down the button for about 6 sec .. which brings up the red light. But instead of shutting off it showed the red light for about 1 second and then quickly flickered blue and returned to the blue light every 10 seconds again. Each time I try to shut it off, it goes through the same routine but stays on. What's up?
  • Anonymous Jan 08, 2009
    my blutooth willl not stop blinking blue and even if i hold it for 6 sec will not reset or turn on correctly
  • aveman Feb 15, 2009
    i no dude, i have the same exact problem and i NEED the answer quick cause i need it
  • rrglds46 Apr 17, 2009
    What I did with mine is let it run out of charge (blinking blue the whole time) and then recharge it and use it. Most of the time it still works and connects with the phone..... on a good day, if ya know what I mean.
  • Tim Babcock
    Tim Babcock May 11, 2010
    If it doesn't charge anymore contact Plantronic and give them the code on the headset. There very good about exchanges.
Hey, I have managed to turn off blinking in My Plantronics 665 by
first: Turning off headset,
then pressing volume up and turning it on.
It will blink to show that it is on, , then blink one more time to show, that it is connecting to phone, and thats it, : no more blinks,
So You don't look like UFO :-)
Cheers from PL.!
XRafX
Posted on Mar 09, 2009
  • 2,794 Answers
The clarification was the solution. Wrong drop down selected.
Posted on Aug 12, 2008
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
How can I get the plantronics model 330 to my blackberry curve
Hi 1 - Start with the headset powered off.
2 - Press in and hold the Call Control Button (on/off button) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" .
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros)
Thank You
Sep 01, 2010 | Plantronics Explorer 330 Headset
I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Good luck from Headsets Direct!
Jan 10, 2009 | Plantronics Explorer 330 Headset
Plantronics 220
Aug 14, 2008 | Plantronics - Bluetooth Headset Plus Base...
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
indicator light flashes blue and
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
Apr 15, 2008 | Plantronics Explorer 330 Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
PASS CODE
thanks sooo much this worked wonders!
Nov 01, 2007 | Plantronics Explorer 330 Headset
Headset setup
http://www.plantronics.com/north_america/en_US/products/cat1150057/cat1150057/prod5560012?prodfind=true&mftr=MOTOROLA Go to this website, and scroll down to Interactive Bluetooth Pairing Guide. (Plantronics 330 - V555 doesn't show 320 and instructions will be similiar). Click on Interactive Bluetooth Pairing Guide and a tutorial will walk you through the steps. Have headset and phone together when you do this and both must be charged. Hope this was helpful. Pam
Jun 11, 2007 | Plantronics Explorer 320 Wireless Headset
Plantronics Explorer  330 Headset Logo
883 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
