Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either. Turned off, turned on, tried every button combination. It acts as if it is playing, which no deck lets you eject when playing. But tapes are stopped. It acts if they are both in dubbing mode or something. The "carriage" with the two rollers and play/recording heads will not lower away from the cassette tape on either side to allow the eject latch to release. actually its not the same but similar: the denon Dual Cassette Deck DRW -660 's fast forward stopped working on both decks. Both decks still play and rewind., (different belts?).
Belts have become too slack to allow mechanism drive. Have replaced
Posted on Aug 15, 2008
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Feb 09, 2014 | Denon DRR-M30 Dual Cassette Deck
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Playback options
If I were you I would get that side repaired for the following reasons 1) the wear on the record head is the same on the B whether you record or play 2) the gap is a compromise if it is a record/play head and for play back only the quality is better albeit only seen on instruments . 3) Cassette machines will be very dear and scarce as the factories appeared to have stopped making them. If you have the quantity as I have then if your record side's head is more of value as you cannot record on the head 4) Is your recording side a "3 head " unit giving you "off the tape" recording capability.5) You loose the ability to do trick recording by adding voice with music
This is the reasons for the time being If it is the unit in your pic then it was a very expensive unit
May 25, 2013 | Denon Audio Players & Recorders
Need instruction manual for denon drw-660 dual cassette deck
http://www.user-manuals.com/advanced_search_result.php?keywords=denon+drw-660+&osCsid=11873a748fd5790e73fdb0587299c24e&x=10&y=14
$10
You may find what you are looking for in another manual. Denon has some manuals on their website www.denon.com. Look for SUPPORT tab, then service manual. On the bottom of that page, they have info for some discontinued models. Read them and you may have the answer to your questions
Mar 15, 2010 | Audio Players & Recorders
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Cannot get dual cassette deck to record, denon DRW-660
check the drive belts inside the unit could be broken or slipping. farr64
Apr 29, 2009 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
556 people viewed this question
 Grubhead
Grubhead
