Question about Samsung MW1030WA Microwave Oven
It keeps starting up on it's own.
It will beep and just turn on by itself with nothing in it and no one touching the buttons. I'm assuming this is dangerous. Should I just get rid of it?
  • Samsung Master
  • 9,098 Answers
You should keep it unplugged until it is fixed.
You have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you reply back with your brand and model number, we can point you to a part supplier.
If you would like to have us do this job for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly (and include your model number) if you need more help.
Posted on Aug 18, 2008
My Oster Microwave #OM1201EOVG beeps when plugged in and will not stop. Just beeps continually. Is it broke?
probably bad touch pad, the unit thinks your standing there pushing and holding down a button on the touch pad. Will need new touch pad or main PC board. Tough pad cheaper, more common, start there.
Oct 06, 2017 | Oster Microwave Ovens
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Jul 03, 2013 | Microwave Ovens
Frigidaire microwave oven model # ffmv162lba seems frozen, pushing buttons does nothing
I have the exact same microwave and had the same issue with it having locked itself. I held the Stop button for 5 seconds and it unlocked itself with a beep. That was easy!
Sep 13, 2012 | Frigidaire Microwave Ovens
KitchenAid kemc308kss0 Micro/Oven Combo Microwave: At the end of any cycle there is a four-tone beep that will continue to beep until KINGDOM COME until you either a. open the door b. press cancel. That is...
From page 7 of your owner's manual:
All Tones (combination oven models only)
All of the above tones are preset on, but can be turned off.
To Turn Off/On: Touch and hold STOP TIME for 5 seconds. A
tone will sound and “Snd oFF” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd on.”
Tone Volume
The volume is preset at high, but can be changed to low.
To Change: Touch and hold the number pad “7” for 5 seconds. A
tone will sound and “Snd Lo” will appear on the lower oven
display for 3 seconds. Repeat to change back to “Snd HI.”
REMINDER TONES
The Timer and Timed Cooking reminder tones are preset on, but
can be turned off. Reminder tones do not include end-of-cycle
tones. On combination oven models, if “All Tones” have been
turned off, the reminder tones cannot be independently turned
on.
Timer
To Turn Tones Off/On: Touch and hold TIMER SET • START until
a tone sounds. Repeat to turn back on.
Timed Cooking (combination oven models only)
To Turn Tones Off/On: Touch and hold COOK TIME until a tone
sounds and the lower oven display returns to inactive mode
(blank). Repeat to turn back on.
Apr 26, 2010 | KitchenAid Microwave Ovens
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
Emerson MW8997B desktop microwave beeping
Hi, probably something happened with the PCB due to an abnormal current fluctuation.
You should go to a service center.
Nov 13, 2017 | Emerson Microwave Ovens
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
Samsung MW1030WA Microwave Oven Logo
225 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
