Question about Kenmore Elite 45986 Front Load Washer
F 01 code won't come off, washer won't start
I hope you can helm Benimur. I really need to get this washer going. I probably have 20 loads to do and it piles up each day that goes by. I stopped the washer 1 minute before it completed the wash cycle and I got an F-01 Code flashing. I stopped by the Sears store in St Joseph, MO, and they didn't know what to do with it, and of course, my warranty is up. My machine is an HE2Plus Kenmore front-loading machine. I downloaded the codes and the trouble shooting guides but they don't work. I've unplugged my machine for over 24 hours and I still get the F-01 flashing. What can I do?
  • 2 more comments
  • bigtau06 Oct 13, 2008
    I have the same problem.  I just purchased a Kenmore HE2 Plus front loading washer in June 08.  The washer is now flashing F-01 everytime I push the start button, regardless of Cycle, Speed, etc.  Fortunately, it is still under warranty but the Sears repair tech. cannot come out to fix for over a week!!!!  I started researching myself and there are many people with the same problem.  It is apparently a "communication" problem between electrical boards in the washer, however, I cannot find a fix that I can do myself; must get repair tech.  I would love to find a solution myself so I don't have to wait so long for repair.  Unplugging does not seem to work.
  • Anonymous Oct 25, 2008
    same exact problem. any solutions out there? what did the repair techs usually do? thanks
  • greg ewchuk Nov 11, 2008
  • tracynmike Dec 31, 2008
    I turned a cycle off with one minute to go. Now when I try to use the washer (Kenmore HE2Plus Frontloader) I get the F-01 error code. Downloaded tech sheet from internet, ran through diagnostic steps, and nothing has changed. Left unit unplugged for some time. Nothing seems to help. This is a BRAND NEW machine - probably used for two months. But, I bought it used from a tenant that owed us rent, so I don't know if I'll be covered under warranty. Thanks for any help you can provide.
You have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Posted on Nov 02, 2008
2 Suggested Answers
  • 1028 Answers
SOURCE: F 01 code won't come off, washer won't start
change control module remove top right front corner white or gray box
Posted on Aug 28, 2008
Error code 20 Washer stops, beeps and is still wet. What's up? No error codes chart is found on frigidare website.
Greetings,
you need to go to your pump and clean it out..its probably full of change and hairpins and stuff like that....
Dec 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Washer #WFW8300SW01 will not operate.
There's a couple of reasons for the F-01, most common is a bad relay on the main control board. (CCU)
This washer will also flash that code if:
1: Either the back or front access panels are removed while operating, there are ground safety switches that are held closed by the panels.
2: If the power supply outlet is supplying much less than 120V (usually would need to be 112V or less to cause it)
3: If the polarity is incorrect (hot and neutral reversed) at the outlet
4: If there is an open ground at the outlet.
The easiest way to check 3&4 is with a simple plug in outlet tester. I have seen all of these problems throw an F-01, but I would still say 9 out of 10 times you have no option but replacing the CCU. Make sure to double check your manual about the warranty info, as some electronic controls are often covered beyond the 1yr standard warranty. If you're going to replace it yourself, it is accessed by removing the top panel, and is located towards the front, right side of the cabinet, and has a zillion wire harnesses plugged into it. When replacing the board, note that there may be some harness connections available on the board that are not used, mark them as such. Hope this helps.
Nov 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
SUDs followed by F 35 error code
its junk and it should be a crime t sell to hard working people never did work good and it needs to go back across the ocean junk yard won even take it
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My machine is flashing F-01 Hotpoint ultima WT960
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Jul 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer- lights go on, but it won't click/lock to start the load s
it is probably the door lock asm itself but lets try the diagnostic mode. Usually on the newer duets when the lock quits you get a quick series of beeps upon pressing start.
On the old style (red leds, no teardrop) set drain/spin cycle, no spin option press prewash 4 times quickly
new models (green leds, teardrop front) the old way may also work but will only start factory test, no code display. instead with unit off, select any one option key, press and hold 4 secs, release 4 secs and repeat till all lights come on (3 or 4 times) then it will flash any f codes, press that same key again to advance to the next code if any (most recent code first) then it will go to display software versions (n:xx etc)
when it shows C:00 the door should lock at C:01 it will fill with cold water this is the factory test routine it will advance automatically. some steps may take a while but should complete them all and turn off. we are of course interested in if it locks here and advances. a F code may still get displayed.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have an error code of F-01 on my Kenmore HE2 Plus washing machine. What does this mean and how do I fix it.
Your washer needs to be serviced by a professional. That error code means there is a communication error between the Control Unit and the EEPROM; the CCU needs to be replaced. Check to see if your product is still under warranty.
Refer to page 2 of this service manual:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208540259.pdf
Mar 09, 2009 | Kenmore HE2 Plus Front Load Washer
Aug 27, 2008 | Washing Machines
When i try to start my computer it gives me the option to repair or start windows normally....when i try to repair it gives me this error code: 0xc00000e9..... and then when i try to start normally it...
where is asking for start normally look for another option called last known good configuration select it and see.
if he does not work insert your window cd into drive it will tell you press any key to boot from cd rom you press then it will get to a sgtage it will ask you press r to repair or press enter to continue you press r it will take you to dos environment type chkdsk it will scan and recover all lost data then type exit to restart then it wil work
May 31, 2008 | Toshiba Computers & Internet
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore Elite 45986 Front Load Washer Logo
174 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
