Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
Monitor works on and off
I have a Gateway FDP 1830. when i turn the power on sometimes it turns on and stays on some other times it powers on the shuts off.
  • thinker55 Nov 26, 2008
    I think I have the same issue. The monitor flickers for a few seconds, then video shuts down. Power is still green. Turning it on and off multiple times sometimes brings it up -- and once up, it is fine, nless it goes to standby or is shut off. Then you can't start it again.
  • Victor Castro
    Victor Castro May 11, 2010
    When you Turn it on and then it shuts off, Does the power button led turn amber or stays green?
    Check, If its green do you see like a super dim display if you look at the monitor from a glare?
    Let me know what your answers to the above questions are, and I can help you out.
    Scholar:
  • 53 Answers
After usual overheating the capacitors, the weakest spot in FPD1830 are four chip resistors located in the inverter board a bit above the middle, you can recognize them as they are bigger than others and located all four in one row. Holding by tweezers simply re-solder them to get rid of micro-cracks in the tin between pads and resistor contacts.
Posted on Sep 09, 2009
I have a Gateway FPD 1830 Monitor. I have to turn it on usually between 30 to 50 times to get it to turn on. What is wrong, and how can I fix it?
The power supply, the inverter, or the lighting tubes may be defective. I would bet that you need some new capacitors in the power supply or possibly some transistors. Those are the two main failure points that cause the quick power supply shutdown. It detects overload and tries to save itself from total destruction by shutting down.
I bet on capacitors, especially if you never turn the power off but let it sit in standby all the time.
Oct 27, 2014 | Gateway FPD1830 DVI/VGA 18-inch LCD Flat...
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
Complete power failure on gateway fpd 1830 monitor on last bootup. no light on power button and nothing on screen . A fuse maybe ?????
Could be the fuse. But typically it is the caps on the output have failed.
Usually can find repair kits on e-bay and repair if you are experienced.
Nov 04, 2013 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor just stopped powering up one day. Is there a breaker or something?
There is main power fuse in the power supply module, but if the screen flashes on for seconds, then the problem is in the inverter board due to bad caps (very common in this model): http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=fpd+1830+power+supply&um=1&ie=UTF-8&ei=y_-7S_uqDI628wTYvsDkBw&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CB0QrQQwAg
Hope my information will help you out.
Apr 07, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
Gateway FPD1530 Backlight turns on, but no display
has to do with power i can get myin to stay some times but then the same thing hapens to me u have to buy a new power board wich is esy to replace and i have had min as a second screen for like 4 or 5 years now with no probloms so its just from over use..
Jul 08, 2009 | Gateway FPD1530 15" Flat Panel LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
224 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
