Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum upright
Water was sucked into vacuum on accident and it hasn't worked since then. i put it in front of a fan to dry out but it still won't come on. what do i need to do?
  • 446 Answers
There could be shortage in the motor because of the water, you need to send this to repair shop asap
sorry about that
Posted on Aug 12, 2008
Kirby shampooed won't suck up water
The Kirby shampoos the carpet but does not suck up the foam solution like an extractor does. The foam is supposed to crystallize the dirt then after the carpet dries you thoroughly vacuum it.
Nov 20, 2017 | Kirby Vacuums
Kirby shampooer not sucking water up
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
NOT SUCKING UP THE WATER
The Kirby shampooer isn't designed to be a extractor.What the shampooer does is create the foam,and the brushroll on the shampooer works it into the carpet.After the carpet is dry,(about an hour,)switch to the vacuum,and the vacuum picks up the dry foam.
Dec 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
My kirby sentra work **** up water when using the shampoo'er
it's not supposed to **** up any water
see your manual
work in the shampoo then let it dry before vacuuming
Dec 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria shampooer
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Upholstry set up for ultimate g kirby.
Remove the entire cloth bag assembly and put the hose on the side where the bag came from. Remove the power nozzle and put the intake guard onto the front. (this is in your attachment set...the only one with little hooks that sit on the bar in front) You can change from the long handle to the short if you'd like also. You get the handles off by pushing the "seatbelt button" located at the rear bottom of the handle and pulling the handle straight up and out. Now, put your spray gun on the hose. Don't forget the little suds nozzle that goes on the end of the spray gun. I like to use a half and half solution of Kirby shampoo and water in the gun. It makes a nice dry foam that only wets the surface of the furniture. If you use more water, it takes longer to dry.
If you need a manual (book or DVD) for your Kirby, try this link....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped...
Marci
Mar 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria carpet shampooer
you dont **** out the water....if you use the reccomended Kirby shampoo there is no need to **** out the water because it is a semi dry liquid ...it will dry by its self in about 1 hour....I,ve been with Kirby for 16 years now ...i will know
Jun 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
119 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
