Sharp copier I have a Sharp AR-200, recent a "check panel" message popped up, since then we can not make copy though everything looks normal. please help... and pardon my english.
  • john533 Aug 13, 2008
    yes, all the covers are properly shut. I believe there is something wrong with the sensors.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are all the covers properly shut on the machine?
I have the same Sharp AR200 and got the same error message this AM on startup. I opened the the paper guide door on the r side by the bypass tray and closed it firmly and the check panel message went away.
Posted on Sep 01, 2009
Posted on Aug 13, 2008
  • 2,794 Answers
If there is something wrong with the sensors it can be related to the cover as well.
If you turn the power off and back on again. Does the messsage still appear after that?
Sharp ar 5320 hwo to repair u4 200
check the duplexer which is what is used by the copier to print on the other side of the copy
Aug 07, 2014 | Sharp AR-5320 Black and White Copier
Sharp AR-5316 F5 ERROR
check the exsposure lamp this error relates to damaged or blown lamp also you check this when you turn th ecopier on you should see it self test at hte start up if there is no light it has blown or connections are bad
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
No error message but copier light doesn't come or number of copies doesn't work
let it run eventually the toner lite will come on, sharp copiers will run an extended period trying to add toner to the developer. developer is 70% iron filings and 30% toner as it uses the toner it cycles more in to stay at the proper level.
Apr 14, 2009 | Office Equipment & Supplies
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Sharp AR-M201
no. i cant print. its showing red light and user guide attention
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M237 Copier
you check the optical unit and laser unit glass and cleaning. the next check drum counter process unit counter.
May 10, 2007 | Sharp AR-M237 Copier
218 people viewed this question
