Question about Dishwashers
I have a GE triclean dishwasher that leaks when it is filling. It is ok when washing and draining. The leak seems to come from a metal plate in the center bottom when I take off the kick plate
Here is the possible solution. The incoming water goes through the valve and then to the black hose going up on the left side of the dishwasher, the hose goes up then bends and it's end is just inserted on some kind of pocket. I think the end of the hose in your dishwasher just looseened and it spills water from this pocket. To fix it you need to pull the dishwasher just a little bit from under the countertop, (make sure to unsrew 2 screws up there) until you get access to the hose and then insert it deeper in the pocket. I would also attach the hose to the side of the dishwasher with the duct tape.
Posted on Jan 17, 2009
GE Dishwasher leaking
HI,
If you're just looking at the machine the problem is not going to be fixed..
and now the question: in witch cycle is leaking?
fill, wash or rinse?
can be...for fill...one hose from filling is broken.
for wash...mechanical seal from wash motor, the plastic manifold,one gasket.
rinse..manifold or hose for the rinse...rinse pump..
for drain..solenoid for drain, the hose for drain..
Anyway you must open the machine first of all and see.
Good luck
Jun 30, 2013 | Dishwashers
LDF7932ST leaks while filling
Has anyone checked the drain hoses inside the machine. My LDF7932 dishwasher was doing the same thing and it turned out to be one of the drain hoses had a crack that was leaking causing a short in the wash motor and a leak in the machine--hope this helps.
Good luck
Nancy
Dec 19, 2012 | LG LDF7932ST Builtin Dishwasher
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
My siemens dishwasher pump seems to running constantly and will not stop when the door as it usually does any ideas
This is an indication that the overfill float has been activated. The unit either has a clogged drain, or the fill valve is defective and letting too much water into the tub.
There is also a possibility of a leak underneath, perhap`s the wash motor or drain motor, but you`ll need to either have a look or call in a pro to check it over.
You can look with the aid of a flashlight by removing the access panel/kick plate at the very bottom. **If you are going to check on your own, shut the power off at the home service/breaker panel**
The kick plate will be fastened by 2 screws, one one each side to the left & right. Look for leaks around the drain pump, off to the left slightly from center, the wash pump, off to the right from center, and maybe the inlet/water fill valve, off to the left far from center.
(The wash pump`s have a known history of face seal wear and are prone to leak. Look for sign`s of water between where the motor and pump housing come together, i.e. water deposit/scale left behind).
The Bosch/Siemen D/W also have had issues with defective inlt/water valves failing, It`s a good idea to monitor the water level in the dishwasher throughout a cycle or when not in use to insure it isn`t filling when not energized or overfilling when in use to determine if this may be the cause.
Hope that helps, good luck.
macmarkus :)
Nov 30, 2009 | Siemens Dishwashers
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore Dishwasher leaking from bottom but not while draining....
Leak is associated with the water pump, either a hose or seal
Sep 29, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Bosch dishwasher is permanently draining even when the door is open. The draining usually does not stop, but on the occasions it does the wash cycle only last a few minutes before it draining again.
THERE IS A FLOAT WITH A RED SHAFT /LEFT SIDE AS YOU LOOK INTO THE BOTTOM OF MACHINE. AFTER TAKING OFF KICK PLATE. IT IS GOING TO DRAIN IF THERE IS A LEAK FROM PUMP OR HOSES FILLING UP THE PLASTIC BOTTOM OG MACHINE . KEEPS A LEAK FROM GOING ONTO YOUR FLOOR.. . MY GUESS IS YOU HAVE A LEAK DOWNTHERE AND NEED SERVICE.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
332 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
