Question about Maytag MER6549 Gemini Electric Kitchen Range
Some buttons on touchpad do not respond
On our Maytag MER6549 double oven range, the upper oven buttons do not respond (except the Keep Warm button), and neither of the "Light" buttons respond, and (on the right hand side of the display) the 4, 5, 6, 7, 8, 9, 0, Timer One, Timer Two, Cook Time, Stop Time, and Clock buttons do not respond. The top row of buttons on that R/H side DO work (Auto Set, 1, 2, & 3). It acts as if a wire (or pc board wire trace) common to those buttons is "open". I'm very handy, but can't figure out how to determine where the problem might be and how to fix it. A new "Clock / control" is over $250.00. Any suggestions would be appreciated.
  • wgates Feb 08, 2009
    I have the exact same problem (the buttons that don't work are the same, along with the ones that do)....did you find a solution....is it the $200+ clock???
  • Maytag Master
  • 3,361 Answers
Replace the touchpad.
Posted on Mar 09, 2009
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
We have a maytag oven. all the buttons work except for the bake and light button.Mod # umc5200aaw
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
Jul 06, 2011 | Maytag 30 in. Electric Single Wall Oven...
The "cancel" button for the upper section of my maytag gemini gas range no longer works. I used it yesterday and in order to get the oven to turn off, I had to unplug the range from the wall. Help!
Mine was doing the same thing. It was a stuck button under the touch membrane. If you are slightly mechanical you can fix it yourself, by first unpluging the oven from electrical power. Remove the upper panel, by taking 2 screws in back off. Also 2 screws on bottom. You can now tilt the upper control panel down to get at the controller itself. I removed it and unstuck the button. Works fine now.
Aug 09, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Sep 09, 2008 | Maytag Kitchen Ranges
Oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Sep 09, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Range
F1 on Maytag = Bad touchpad or Clock.
Mar 20, 2008 | Kitchen Ranges
Maytag MER6549 Gemini Electric Kitchen Range Logo
450 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
