Question about HP Color LaserJet 2600n Printer
Green lines on paper
Aloha
I have been having trouble with two green lines onboth sides of the paper and on the door transfer screen i clean it of but is back as soon as I print again
Mahalo Mary
  • 2 more comments
  • mouseka Aug 25, 2008
    We are also experiencing 2 green lines down any printed item. It appears to be dust on the black glossy paper inside but reappears each time I remove it.
    Kerrie
  • chapsetc Sep 20, 2008
    I got it fixed after a few days with the HP trek, and yes it was that my cyan toner was leaking they sent me a new one and it works fine.
    I did not think it was the toners as it was over 49% full, I am a Happy camper now
    hope this info will help future folkswith this trouble
    Mahalo Mary
  • Anonymous Sep 26, 2008
    We are also experiencing the same problem but instead of 2 lines our whole page is green.
  • driftos Sep 26, 2008
    We are also experiencing the same problem but instead of two lines our whole page is green.
  • HP Expert
  • 141 Answers
Leaking toners
Posted on Sep 20, 2008
  • steve shroder Sep 20, 2008
    the first step to any print quality issues is to replace the toners one by one. that goes for any printer.
SOURCE:
My mp161 is showing a dashed line on the right side of the paper. Visible even if I copy a plain white paper ... dashed line still shows. Checked the pcu. No issue.... checked on the transfer roller... I...
first clean the inside of the printer as there might be tiny strips of paper that cling to the print head assembly, second open the scanning area and clean the camera as tiny lines came from dust that was being read by the camera as an image.
Dec 07, 2013 | Office Equipment & Supplies
How to print on both sides of the paper in canon lbp2900?
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jun 06, 2011 | Office Equipment & Supplies
Black line on copies
press function 6-4 start and let that print .. if you have no lines then the machine is the scan glass..
to clean scan glass open the control panel door but not the toner door.. you will see 2 green plastics on either side of the machine.. press them both towards the center and lift..when done properly you will lift the white plastic plate about a 1/4 inch.. tilt that up and clean the glass with windex or alcohol..
if this does not work you need a tech because you scratch the glass
Jun 22, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Re-fitting an oven door
1. Open the front door you did
2. Open the clips at the hinge housing (2) on
the right and left hand sides of the front
door by lifting them up. you did
Hold the door onboth sides and then close the door and lift
the door up to remove it. assume this is what you did. Refitting is the reversal of removal.
Jan 20, 2018 | Ovens
HP 2840 Jam in Print Paper Path
There are 2 primary paper sensors. One is the registration sensor where the paper feeds in, the second is associated with the fuser unit.
The first sensor is located under a cover under the transfer unit.
i) Open the door
ii) Lift out the transfer unit (Q3964A)
iii) Locate the black plastic cover plate with a small green flap in the centre. This assembly is directly under where the transfer unit was installed.
iv) There are 2 shiny screws that secure this cover plate. Carefully remove these screws.
v) Lift out the black cover plate by lifting the left section up first which allows the right section to come clear of gears.
vi) Check for paper obstructing the small movable lever under the cover plate.
vii) To reinstall the cover plate, insert the right hand side down first and line up with the mounting holes.
I can supply photos if required.
Jan 10, 2009 | Ricoh Aficio 250 Copier
Printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Sep 16, 2008 | HP DeskJet 6540 InkJet Printer
Printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Dec 31, 2007 | Kyocera Mita FS-1920 Laser Printer
Lines on the page
Hi,i will do this: Remove toner,then remove developer unit.Try to clean magnet roller on developer unit with dry cloth, if see lines on roller.Pull out paper transport unit(green handle ) and clean transfer roler and vacuum it.Then ,when is paper transport and developer unit out, remove drum unit(open door on the left side on the printer and pull out drum). Remove Corona from drum unit.Remove and clean grid,corona inside and corona vire.
Check fuser and drum for scratches.
Nov 23, 2007 | Kyocera Mita FS-1920 Laser Printer
HP Color LaserJet 2600n Printer Logo
256 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
