Question about DFI LanParty KT400A Motherboard
Red lights on board
I replaced the caps that gotten damaged and now when I plug the pc up it lights green. When I press the power button they turn red. What is causing this? Also where can I get the diagram on how to wire this board again to make sure i have it correct
  • 112 Answers
I never had green lights on my motherboard, they have always been red and it runs fine. the mother board was made with red led lights. if its not working right, it's probably the switches on the mother board, normally make the first switch on, and the other 3 off.
Posted on Jun 20, 2010
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Microsoft Xbox 360 Console
WII DOES NOT TURN ON AT THE POWER BUTTON
remove the power cord from the wii. hold the power button in for 15 seconds.
plug the power back in. if the power light comes on check the color.
green is on, yellow is standby and red is totally off.
if there is a light press the power button and see if it turns on. if it does not then from a Wiimote, press and hold the power button on the remote. this should turn the console on. if the console does not turn on and the remote batteries are good you can try one more thing IF the light is on.
press and hold the reset button for 10 seconds on the system. disconnect power and replug. if you still cannot turn it on then your system is bricked or damaged and needs replacement.
in any case the power button is broken you can turn the console on and off from any remote
Aug 24, 2011 | Nintendo Wii Console
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
When I plug the power cord in the wall outlet, the red light turns on indicating that power is there. when I press the "power on" button on TV or on the remote, the green light turns on for one...
Right now the standby 5vdc is working but it may have gone into safety shutdown due to failed power supply or shorted circuits in the backlight inverter board. You need to troubleshoot it to narrow down the causes first before buying the wrong parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 01, 2010 | Norcent Technologies LT-2722 27 in. LCD...
Will not power up. Green light on power source
Red battery light means battery is charging. It should start up even if battery is low. Try pressing on the area above and to the right of the power button, while you are pressing the actual power button.
May 13, 2010 | Acer Aspire 9500 Notebook
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Viewsonic N3251 doesn't turn on right away
Solution... Call viewsonic and **** till you get a new one (diff model). Good luck, you're going to be on hold forever.
Nov 15, 2007 | ViewSonic N3251w 32 in. LCD HDTV
DFI LanParty KT400A Motherboard Logo
365 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
