Hi arjeevergel ,
The USB drive should work fine even if you have removed it while formatting your hard disk (if this is what you mean when you say formatting computer).
Try connecting the drive to some other slot after you install the operating system and check it it works.
If it does not work , then you can probably check it in your neighbor's PC whether it's been detected or not , if it's being detected then the problem could be that your USB ports have been disabled which you need to enable via BIOS or the hardware manager.
Hope this helps ...:)
