Question about Linksys Ultra RangePlus Wireless Routr Router
Laptop the isp is verizon and the modem is wetell 6100. the router is linksys WRT54G2
  • 298 Answers
Alright, first we'll configure the router for internet connection. I have a links here for you on how you can manually configure the router for internet connection. click here. Just let me know if you will have a problem getting the router online. After we setup the router for internet we will configure the router and the wireless for wireless connection.
Posted on Aug 13, 2008
My WRT54G2 will not connect to the internet I am using another router also
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 18, 2010 | Linksys WRT54G2 Wireless Router
Setup difficulties. Can't complete step 4/4
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
May 02, 2010 | Linksys WRT54G2 Wireless Router
I need a free download driver for wrt54g2 v1
Click Here for step by step by instructions
Mar 18, 2010 | Linksys WRT54G2 Wireless Router
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
Connecting a laptop.
on connecting your laptop wirelessly, it is best if you set the router to have wireless security first.
accessing the router's setup page:
open IE, then type http://192.168.1.1 on your address bar, it will ask you for a username and password, thats both admin (these steps will depend if you have changed the settings on the router)
once opened, go to the wireless tab, change your Wireless Network Name (SSID) to something esle instead of Linskys, like your name perhaps. then set the channel to 11ghz and hit save settings.
now look for a Wireless Security SUBTAB, enable to wireless security, under security mode select WPA-Personal (PSK) set your algorithm to TKIP and make up a password on the blank space that says Passphrase / Pre Shared Key , that will be you wireless security code. now hit save settings.
in connecting your wireless laptop, make sure the wireless adapter on the device is enabled and it will automatically locate the wireless network and wil ask you for the security code, once you place it, you will get connection.
Aug 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Connecting my westell 6100 modem to my router
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
Dec 09, 2007 | Linksys Wireless-G WRT54G Router
Linksys Ultra RangePlus Wireless Routr Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
