I have a D-Link DI-524 router. I bought it a few years ago but found out I couldn't use it with AOL. I'm trying again to set it up since I'm now getting DSL from Bell South. I have wired it according to directions but the WLAN light keeps blinking? I did punch the reset button to see if that would help but didn't see anything different. I am connected to the internet but when I type in my IP address for the d524 nothing comes up? Help?
  • 928 Answers
Check your IP address first.
Click start then run then type in CMD
in the command prompt type in ipconfig then hit enter
Your default gateway is the IP of the DLINK
if that does not work.
press the reset button for 10 seconds then pull out the power
Wait 5 seconds then plug the power back in.
To access the setup page easier
Click start then run then type in HTTP:// IP of the DLINK
Posted on Aug 12, 2008
    Scholar:
  • 174 Answers
Upgrade the firmware from the www.dlink.com and see its working
  • Matson Kurian
    Matson Kurian Aug 13, 2008
    Its important to know your network structure and any firewall setted from your side or your service provider - May be firewall restricting you from connecting to AOL
I have router DI-524 and am unable to connect to internet thru this router. But it says, it is connected
I would do a hard reset by pushing the small button on the back. You will need a small pen to push it. Push and hold down button till the lights flash I would/ say 10-15 seconds should be good enough. Once it's reset try setting up all of your settings again. Remember if you have dsl you will need you username and password to be inputed in some cases. If it is broadband most likely you will not have to bother with username and pass hope this helps.
Nov 30, 2009 | D-Link AirPlus DI-524 Wireless Router
Have a d link di 524 how do I secure the wep password I set a year ago
Change the password, monthly.
Use a mix of upper-case, lower-case, and digits.
Or, try the the first letter of a common-phrase:
I J(ust) W(ant) T(o) R(ock) A(nd) R(oll) A(ll) N(ight) --> I J W T R A R A N
or
A(ll) W(e) A(re) S(aying) I(s) G(ive) P(eace) A C(hance) -> A W A S I G P A C
Nov 14, 2009 | D-Link AirPlus DI-524 Wireless Router
No power for DI-524
Have you tried the reset feature, small button near the power port.
Hold it down for thirty seconds with the unit unplugged. If that doesn't work you may need to buy a new router as something may have failed some time ago and just not been noticed until it was turned off.
Try the reset, but I suspect whatever killed your modem likely killed the router at the same time.
Hope this Helps FixYa,
Chris
May 09, 2009 | D-Link AirPlus DI-524 Wireless Router
Does DI-524 spport WAP
It looks like the 524 will support WPA-PSK.
Try this:
http://support.dlink.com/faq/view.asp?prod_id=1506&question=DI-524
If your 524 doesn't look like this you amy need to update the firmware.
Good Luck
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect to my router via the IP in the browser
Check first the cables and connections, and the broadband filter.
You need to connect through cable to configure the router.
To access the router panel you need to input the router IP address on Internet explorer bar.
default IP is http://192.168.0.1
If IP is not default, you find out IP by opening the command prompt from start menu>>all programs>>accessories>>system tools (that kind of dos mode). On command prompt type ipconfig/all.
The default gateway is router IP.
On the router access panel default settings are :
User Admin
Password leave blank
See all procedures on manual below.
Copy and paste the address below on your browser address bar.
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
Dec 08, 2008 | D-Link AirPlus DI-524 Wireless Router
I've had problems with this too, if you have not accidently turned it off in the configuration however you should be able to hook up another machine and access it from there. You can also try another browser, for example, it doesn't work in IE but works in Firefox.
Dec 06, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link router : no wireless connectivity
Hi, I put this up on moneysavingexpert and got help straight away. After a few checks, it turned out I'd accidentally slid the wireless switch on my laptop so it was nothing to do with the router after all!! lol
Nov 06, 2008 | D-Link AirPlus DI-524 Wireless Router
New laptop can not connect to Di-524 router
connect the router to pc via a ethernet cable, then there should be a reset pin hole on the back, press this, the router will restart and clear the password, restart pc next, then type in the routers address again and you should connect.
You can then remove the cable and connect using the wireless connection
Sep 04, 2008 | D-Link AirPlus DI-524 Wireless Router
Hello there my names mr kevin kerr, i bought a d-link router last year with my laptop, we got a computer tech person out to set it up to go wirelessly to my laptop now it will not connect wireless to my...
Simply reset router and try connecting to Dlink network unsecured and then secure it again by logging into router.If still not working upgrade firmware on router.
Jul 31, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
David Payne
David Payne
