Question about Sony KP-57HW40 57" Rear Projection Television
Sony projection tv
When i turn on my tv its fine for about 30 seconds then slowly turns completely blue.sound is ok. please help. what can i do to fix it. model #KP57HW40.
  • Anonymous Aug 13, 2008
    turn tv on 5 min later picture fades out to blue screen.
  • cstump Sep 30, 2008
    Can't I just replace a bulb?
Sorry to be the bearer of bad news but I have the same model Sony with the same problem it was just returned from the repair shop (not to mention a $95.00 diagnosis charge) I was told that it will cost $700 to repair. The bulb in the back is gone and Sony no longer makes it so it would have to be re-built from scratch. I'm done.....
Posted on Aug 13, 2008
I have a 2002 KP-57WS500 sony tv. Whenever i turn it on, it is fine for about 5-10 seconds but then the whole screen slowly fades to blue until you see no picture but can still hear the sound perfecly. I...
Unfortunately, the Blue CRT will most likely need replacement. But you can get the entire assembly as a complete unit which makes it a easy removal and installation since the CRT is a complete one. Heres the link to that Blue CRT http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220790336974&ssPageName=STRK:MESE:IT
Jun 04, 2011 | Sony KP-57WS500 57" Rear Projection...
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
1. My Sony KP-57WS500 TV is turning blue after abut 3 minutesof operation. It stays that way for about 30 miunes and comes back with pictures again, but with predominatly blue color. 2. Sometimes the TV...
Sounds like the picture tubes are failing,common on sony. do you notice any thin horizontal lines? You mite get lucky and be able to adjust the voltages. Remove back cover and look inside to see which tubes are lighting up.The front panel below the screen will come off and behind it is a small access cover.remove it. there you will find the voltage controls (its a plastic square with 6 knobs). 2 knobs for each tube, 1 is focus the other is the voltage labeled "screen". they are marked so look closely. Green is always in the middle but sometimes they flip the controls for red and blue so pay attention to which you are controlling .slowly adjust screen voltages to see if you can get it to stay on. If you over do it those thin horizontal lines will pop up and the tv will shut off again. If you already have lines back off the voltage by turning knob to the left slowly until they diappear. If that seems to fix it but the problem but it comes back later, then the tubes are shot. good luck!
Jul 05, 2010 | Sony KP-57WS500 57" Rear Projection...
No picture no sound
Thats great that TV is working fine. How about rating solution as 4 blue diamonds?
Thanks.
Mar 04, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
52'' sony tv rear projection turns blue
it sounds like the blue crt is failing Pull the front off and turn the tv on
When it still has a good picture tap the blue crt
if it flashes blue with lines across the screen then you know it is a bad crt
It might not be worth fixing
Good luck
Jan 26, 2009 | Sony KP-57HW40 57" Rear Projection...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
Kp57wv600 sony tv with red background and red dominance.
completly remove speaker cover untill you can see the electronics. there will be a box with 6 setting screws. on the bottom row of screws , look for the screw with the letter r under it .  verry verry slowly turn that screw counter clock wise untill the picture clears up . good luck
Oct 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
158 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
