Question about Microsoft Xbox 360 Console
My 360 tray says it is always opening
On my 36 dashboard it says the tray is opening and the tray is not opening. so then i press the tray button to close it while its closed then it says opening 5 seconds later
  • Anonymous Dec 18, 2008
    open x360 tray problem is very annoying thing.i opened my xbox but i didn't know how to fix it
  • MrStyrac Dec 18, 2008
    Wow thanks Im sending mine in, in a couple of days, as long as ur warenty still effective give it a go, but ill repost if i find out whats wrong
Hi guys i have the same problem but i tryed somthing note:(this solution works for benq/phllips hard drives) first if open your hard drive you will see two screws behind the lens then turn them both to the left and TADA!!! tell me if it works guys.
Posted on Apr 27, 2009
Mine dose the same thing. we cant play any games or movies on it any more. alot of my friends are having the same problem. i talked to microsoft a few months ago and they say i have to pay to have it fixed. sounds to me like it should be a recall if everyone else is having the same problem. how lickly is it that we all broke our x box in the same way and its our falt. let me know if you find anything out i would love to have mine working again concidering its our dvd player too. my email is [email protected]
Posted on Aug 13, 2008
SOURCE:
If game door is left open, how do you get it back open once it close?
Do you mean the disc tray? To re-open it, you can either press the small arrow button on the Xbox itself or hover over the game while on the dashboard and press X
Nov 22, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 tray opens from dashboard but not from the eject button
the eject button has been pushed back try opening 360 and pulling it pack into place
Mar 28, 2009 | Microsoft Xbox 360 Elite Console
I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Mar 28, 2009 | Microsoft XBOX 360 ARCADE Console
The Disc Tray won't open!
press the button the it might go on if not take it back to the shop and say the disk tray wont open lol]
Jan 25, 2009 | Microsoft Xbox Console
Xbox 360 disk spins while ejecting
i had this same problem, so i figured, "what the hell?" i might as well open the dvd drive up and clean it out. so i looked for how to video for taking apart my 360 and opening the dvd drive on you tube( this voids your warantee of course) and i cleaned all the dust out with compressed air and swabs dipped in alchohol. this worked for me so i hope it works for you.
Oct 22, 2008 | Microsoft Xbox 360 Console
RE: Disc Tray won't open ~ help needed
The disk drive is broken, and will need to be repaired, if you have a game stuck in there, take off the faceplate and straiten out a paper clip. Poke it into the small hone under the cd drive until it manually opens.
Jun 23, 2008 | Microsoft Xbox 360 Console
Not reading any discs
My xbox is not reading discs. please help.
Jan 13, 2008 | Microsoft Xbox 360 Console
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Disc tray won't close!
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
Oct 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
301 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
