Question about Brother IntelliFax-4100e Fax
Cannot receive fax with voip line.
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Alice
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Posted on Sep 01, 2008
SOURCE:
Fax over voip often does not work
That is usually true! Cable companies such as Cox and Comcast use a WiFi system that does allow fax transmissions
Oct 31, 2017 | Xerox Office Equipment & Supplies
How do I change the setting in order to use fax on voip line?
Hi
The data transmitted during a voice call and a fax transmission are converted to digital pulses in the same way, so sending is not the problem. The problem is at the receiving end. A receiving fax device has to be set to pick up the call before the voice call device, as it is the prompt of the fax transmission signal that makes the receiving fax switch from send or idle to receive mode.
So, if you are faxing over the internet the intended recipient's setup is a complicating factor.
Since faxing to landline fax machines via VOIP would incur a charge, you might consider a cheaper software solution such as eFax (www.efax.com), which enables the receiver to receive the fax as a PDF document attached to an e-mail.
I hope this helps
Aug 26, 2011 | Ricoh AC104 All-In-One Laser Printer
Fax machine does not receive FAX
The problem is that the codecs used by VoIP IADs are designed to compress voice, not the analog signals sent and received by modems.
In a VoIP Internet world, voice is first converted into packets and then they are sent over the connections that make up our our vast Internet. They may take slightly different times to arrive at their destination. In doing so some packets may be discarded, but the end result is that the receiving VoIP device has enough packets to make a clear and understandable conversation.
We suggest these settings on a fax machine for faxing over VoIP; slowing the transmission rate down and allowing the machine to continue receiving the transmission even though a few bits of data were lost, then faxing over VoIP can become more consistent. Our suggestions in many cases can resolve issues that prevent faxing over a VoIP connection, but not in all cases. If after trying and making all the VoIP fax changes we suggest you still cannot fax over your connection then try a Internet Fax service.
Aug 10, 2011 | HP Office Equipment & Supplies
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
I have a new phone carrier(Vonage) and a new DSL modem from at&t. Prior to obtaining either, my fax machine worked fine. Now, I can't send or receive faxes..(Why)
This is a common issue with all fax machines that use a voip service. Basically, the reception and transmission features of the fax machine are not compatible with voip service. There is a modification that you can perform that usually allows you to avoid this problem, you must lower all transmission and reception speeds of the fax modem; this allows the data to be properly carried over the line without much loss or degradation.
-David.
Nov 03, 2010 | HP 1040 Plain Paper Inkjet Fax
Will not send a fax
There is two things i can think of that can cause this. The number one is if you are using a voip carrier (like vonage or att voip or comcast digital voice) they are usually not compatable with fax machines. You will need either a dedicated fax line or you will need to whats called a fax line from vonage or comcast, or from your voip service. If you are using a phone line test to make sure you have it connected correctly buy simply dialing your cell phone or a friends cell phone (let him know you are going to test) once you do this you will hear a ring and an annoying fax machine tone buzzing in your ear. if this is the case and you do have everthing connected correcly i would put a trouble ticket in with your phone company, to test the line condition of your line (to make sure its not shorting or anything like that)
i hope this helps if there was more information i could do better but hopefully this will help out a bit.
Thanks
Steven
Apr 29, 2010 | HP PSC 2210 All-In-One InkJet Printer
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not receive fax on Canon Laser Calass 710 Faxmile.
Line noise could cause trouble. I don't know if this unit supports VOIP phone lines. Many fax units require a genuine analog line or something that reproduces an analog phoneline.
Can you test the unit with a genuine analog line?
Nov 17, 2008 | Canon LaserCLASS Fax 710 Printer
Brother IntelliFax-4100e Fax Logo
1,379 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
