Question about Toshiba Satellite P30 P35 Series Notebook
P30 Extended desktop disabled
My extended desktop feature just quit out of the blue. I've tried resetting things in properties etc but to no avail. Anyone have any ideas as to what may have gone wrong?
Thanks in advance!
    Scholar:
  • 80 Answers
Try accessing your Graphics card/software. It may just need a promt from you.
Posted on Oct 26, 2008
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
Extended monitor wont extend
can you now see 2 monitor properties i.e. 1 & 2... then identify running monitor ... if it is 1 then select 2 in properties and set it again to be used as extended desktop... open any application and pull or drag it holding it from title bar to the extended desktop....
May 31, 2009 | Acer AL2016W 20" LCD Monitor
Extended Desktop is set as primary monitor
Go to Start, Control Panel, Display, Settings. Here you can change the primary for the secondary and then selecting which will become the primary again.
Apr 02, 2009 | Sony Computers & Internet
How I do disable extended desktop
Windows vista :
Right click on your desktop > Personalize > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
Windows XP :
Right click on your desktop > Properties > Display Settings > Click on the second monitor icon (monitor picture with number 2 in it) > Clear the checkmark at "Extend the desktop onto this monitor" > OK
That should fix it
Oct 30, 2008 | Computers & Internet
Extended desktop rotated, can't turn back.
Click on the extended monitor which is out of sync with the main monitor and click CTRL + ALT + UP
Thanks,
Vasu
Oct 02, 2008 | Microsoft Windows XP Home Edition
I have a problem using the external screen on my acer 5315
I'm assuming you mean you get no picture on the external monitor.
Most laptops have a blue "function" key. some of the other keys have additional functions when this blue key is pressed as well; one of them is to change the display usage. Usually, this can be:
* Internal only
* external only
* internal & external showing same picture
* internal & external as extended desktop
Repeated pressing of the relevant key will cycle round the available display modes. Once you find the one you want, you may have to adjust Windows display options - right click on the desktop and click "properties" then go to the Settings tab.
Jul 21, 2008 | Computers & Internet
Cannot display image on a proector using Lenovo laptop
Ok.I got your point.Actually you're in extended mode.
Once you connect you can have 2 types of output to your projector.
1.Clone mode--> make everthing look the same
2.Extended mode--> have another new space for you to use.
** in extended mode you'll have a background of your desktop.you can drag any running program to that space.
How to setup clone and extended mode
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Under display select you 2nd monitor
3.Below Screen Resolution you should be able to see a checkbox "extended my windows destop on to this monitor"
please check this box for extended mode or uncheck it incase you won't to use clone mode.
takecare.
Apr 28, 2008 | Computers & Internet
Warranty extention
It looks like that is the case. Here is what I pulled from thier website. Extended Service Plan (ESP)There's no doubt that your purchase was designed to give you years of use, however, an unexpected breakdown can mean serious "parts and labor" or replacement costs. Protect your investment by purchasing one of our new and improved Extended Service Plans! Benefits include:
• 100% coverage on Parts and Labor - with no deductible or hidden fees.
• Power surge protection for notebooks.
Extended Service Plan options for Desktops:
2-Year Desktop ESP 3-Year Desktop ESP Upgrade to:
2 years warranty on parts and labor
2 years technical support*
On-site service
Only $99.00 Upgrade to:
3 years warranty on parts and labor
3 years technical support*
On-site service
Only $139.00
Extended Service Plan options for Notebooks:
2-Year Notebook ESP 3-Year Notebook ESP Upgrade to:
2 years of screen repair or replacement
Only $109.00 Upgrade to:
3 years of screen repair or replacement
Only $189.00 Please note: Extended Service Plans may be purchased up to the end of the 12th month (364 days) from your desktop PC original purchase date. The extended warranty option is not available for all products/models. Refurbished units do not qualify. ESP coverage must not exceed a total of three (3) years from your date of purchase.
To Purchase an Extended Service Plan
You can purchase an Extended Service Plan by phone or online chat. You will be required to provide a credit card number and other requested information.
Live Chat Support—available 7 days a week, from 3 am to 12 midnight (PST)
Live Chat now features a new suite of tools that will allow our support agents to assist you more efficiently. With your permission, our representatives can now view and take control of your computer, check your system parameters and provide you with web pages to resolve your technical issues.
Nov 02, 2007 | Computers & Internet
Toshiba Satellite P30 P35 Series Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
