Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
We have a scotsman ice maker that freezes up all the time.
Sounds like the thickness stat is faulty.
Posted on Aug 24, 2009
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
Scotsman flashing f
F means it is in freeze cycle when it flashes it is timing out then it will go to a solid f meaning it should be running in the freeze cycle.
Jan 11, 2014 | Scotsman Kitchen Appliances - Others
Scotsman cme306
Here video. Was long freeze error. found out that it was bad ice thickness probe. Hope this helps to someone
May 21, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why does my scotsman ice machine, model cm250ae-1e, freeze over on ice cube grid?
check ice thickness thermistor if its not working properly timer will never start advancing
Jan 19, 2011 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
286 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
