Question about Refrigerators
Water is collecting in bottom of refrigerator underneath vegetable compartments so much overnight it is coming out of door onto kitchen floor
  • 29 Answers
Check the drain off the coil inside the fridge you can usually find it by looking at the back of the fridge and locating the hose running down to a tray either on top of the compressor or its own receptacle it will probably be blocked,air pressure back up this line usually removes the offending object and allows it to drain again
Posted on Aug 13, 2008
Fridge working perfectly... water leaks onto floor over night seems to be from underneath..
I would check that the water catch tray is on the compressor, this item collects the water from a defrost, it may be missing.
Dec 04, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Water in the bottom of the freezer compartment, collects and freezes ,fills the bottom with 1/2 of ice. continues and runs out on the floor. LG LFX25975 Where is the water coming from? Doors and Drawer...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Water pooling under the vegetable bins on the refrigerator floor enough to fill up the cavity and leak out the door onto the kitchen floor. It is Magic Chef CTB1925DR. We have to constantly pull the...
Leo Ponder
imufo2
Aug 30, 2011 | Magic Chef CTB1821AR Top Freezer...
KTRS22KHWH00 Water collects in bottom under vegetable bins. There is no drain to let it go into a tray underneath....How can I prevent this collection of water ? It can drip over the edge to the...
SOUNDS LIKE A BLOCKED DRAIN
Drain is probably located at top of refrigerated compartment. If you can't see it you may have to remove the the thermostat and/or light assembly at top of frige. Once located a wire can be used to unblock drain. I had same problem and tried to use a wire coat hanger but it wasn't flexable enough. I resorted to a piece of No. 12 copper electrical wire. It negotiated any bends in the drain and was strong enough to clear the blockage.
Mar 07, 2011 | KitchenAid Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water leaking into the refrigerator
Hi, You have a drain plugged in the frezer. Your model # doesn't come up but what you need to do is remove the rear anel in the freezer and clear the ice. If the floor of the freezer has two screws holding it, remove it as well.
Please check the model# again and I can assist you further. There is an after market deat transfer strip you might need to add to prevent this from reaccuring.
Thanks
Vic
May 17, 2009 | Refrigerators
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 27, 2009 | Refrigerators
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
Refrigerators Logo
209 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
