I don't own one, but I'm guessing it has a glass-like layer over an LCD display. The first step would be to figure out if it is the glass that is cracked, which I'm assuming is the case, or if the LCD is what is broken. In either case you will need to find a replacement part. I've had good luck using http://froogle.google.com or eBay to find similar replacement parts. Just search for your devices model number plus screen. After you have the part you need it should be a simple disassemble, replace, reassemble procedure. Hope this helps.
