Question about Whirlpool Washing Machines
Hi my direct drive Kenmore washing machine shakes like a banshee when spinning. I have checked and all 3 springs are connected and nothing is obvious. Any suggestions on what else i can check?...
  • Knollman Aug 14, 2008
    No, I have this washer on concrete floor, the feet are level and all is good that I can see. When it starts to spin with a reg load it vibrates like crazy. Could it be a bearing or something. I have 2 kenmores that have the same problem.
  • Knollman Apr 28, 2009
    yes thankyou, that has given me some other options to look at and try.
  • 10,515 Answers
Hi knollman,
I personally feel there is something that these washing machine companies have to do in regards to vibration during spin cycle.
There are so many solutions :)
1. Balance the load of clothes when you put it in. If it's thumping during the spin cycle, stop it, open it up, move some clothes from the fuller side to the less full side, and see if that helps.
2. Replace the springs inside the machine which suspend the washing drum (open it up, take a look, it won't bite). Perhaps they're all saggy and this is permitting excessive vibration.
3. Put something under the machine to stop it from transmitting the vibrations to the floor of the house. A old sock folded several times and placed under each of the four feet may help. Rubber or foam (piece of an old yoga mat?) will also work.
However, the best solution would be in case all above would "NOT" help :)
In the market, there are anti ******** pads
http://www.gviinc.net/
Make sure you have properly installed the machine...
Check the procedure :-
http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=115
Other things that you need to check....
Most washing machines have a large weight attached to the drum, usually a concrete block. Most washing machines have a large weight attached to the drum, usually a concrete block. It's supposed to prevent too much vibration. Check that one or more of the bolts holding it on haven't come loose.
Also,
There are cases when people installing it hadn't removed the restraining bolts that were locking down the shock absorbers. Oops!
One other thing: some front loaders by spec are only supposed to installed on concrete slabs. You can ignore that (we do), but if you have a front-loader like that, you are going to have some vibration no matter what you do.
I hope this would help you.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 28, 2009
    Genius:
  • 1,665 Answers
Check (adjust)its base to be ok on ground
Posted on Aug 12, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Aug 14, 2008
    Usually it happens when the load of clothes has probably gotten unbalanced.
    Open the lid, redistribute the clothes in the washer, then re-start it.
    To be sure you may try to operate it without any load inside and see if it is vibrating.
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Kenmore direct drive washing machine... there no
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Mar 30, 2010 | Kenmore Washing Machines
On the spin cycle washer thumps and spins fast
Top load direct drive Whirlpool / Kenmore washers use a number of springs and plastic vibration pads between the base and tub to control vibration.
It's possible that one or more of the springs or pads has come loose or broken.
See the following for how to remove the cabinet to gain access to the springs and check them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Nov 25, 2009 | Kenmore 23012 Top Load Washer
Washer shakes as if unbalanced during spin cycle I think that part of the suspension has failed, the result is the washer shakes violently during the spin cycle but otherwise seems to perform reasonably...
Whirlpool / Kenmore top load, direct drive washers use a number of springs between the main suspension plate and base assembly as well as friction pads that are designed to minimize shaking.
See the Whirlpool / Kenmore service manual for top load washers.
It's likely that one of the springs or pads has broken or come off.
See the following for how to remove the cabinet to get at these.
Oct 24, 2009 | Washing Machines
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Hello, my Kenmore 90 series washer is shaking badly on spin cycle and we discovered the tub inside seems to be rather loose, does this mean something may have come unhinged?
This assumes that you have a basic Kenmore2.gif / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Also see the Whirlpool2.gif / Kenmore installation and maintenance manual.
Thefirst thing that I'd do is pull the cabinet and check the levelingsprings and plate pads. These are designed to keep the tub frombouncing against the cabinet during the spin cycle.
Following is a description of how to remove the cabinet.
The Sears diagram shows where the springs and pads are located.
The top load Whirlpool / Kenmore washer has a tub that is designed to somewhat "free-float" The springs and pads keep it from getting too out of control. If one or more of the springs or pads is loose or damaged, the tub can contact the cabinet making a very loud sound.
Oct 01, 2009 | Kenmore Washing Machines
Hi i have a kenmore washer est 7 year old about 4 mont. ago it started shaking bad and walkes all over. no mater how big the load is .is there a censer in it for balence
Check the components in the Machine Base section.
It's possible that one of the springs has broken or slipped from its' hook.
It's also possible that one or more of the three Base Pads which allows slippage between the top and bottom frames has broken.
Sep 24, 2009 | Kenmore Washing Machines
Kenmore washer stock no. 22642 shakes terribly during spin cycle
There is a suspension plate under the tub.
It also has 3 pads on it to support the tub.
There are springs attached to support the angle of the tub.
Check all these parts and repair or replace as necessary.
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series washer shakes uncontrollably in spin cycle.
try this
the washer needs to be leveled on a flat surface to properly function rock forwards then backwards
washing machine have stablizers on there leg pegs this insures it has a proper setting on floor
if this did not help there is a spring under neith that you did not load back to bucket to keep in place
most likely it just needs to be rocked you will know if pegs are seated properly
May 07, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
