Question about Vtech Lands Phones
I have 2 models # TM3111-2 One is plugged in to the phone line and to a power oulet. They both show charging but I don't get a dial tone when I pick up the reciever. My desk phone is plugged into the router and I can get call and call out with it. How do I get the other phones Not near the router to work?
There is a solution which is easily implemented if you have discontinued phone service from your landline carrier.
1. Find the "block" where the landline enters your home and disconnect the wire which enters the block from the phone co.
2. At this point the wires in your home are "dead". If you had a dial tone before, you should no longer.
3. From your t-mobile@home router connect the phone line output to one of the regular phone jacks in the wall.
4. You should be able to now connect your vtechs to any outlet in your home --- regardless of the distance from the router.
5. You also can use your old regular wired phones if you wish to.
Posted on Aug 26, 2008
How to get a dial tone on AEG Chamfer 215-2?
If it was a lightning strike and had a power surge that toasted it you could contact your utility company about a claim.
Oct 28, 2014 | Lands Phones
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
Oct 19, 2011 | Brother MFC-8220 Fax
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    Two questions: We have Panasonic KX-T7630 model How do I change/delete numbers to the personal speed dial numbers. Second, one of our phones has two buttons on the right lit up in Red like there are no...
    If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
    What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
    Sep 28, 2011 | Panasonic KX-T7630 Corded Phone
    I pick the phone up, no dial tone. Display says
    We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
    Jan 21, 2010 | Vtech Cordless 6041 Phone
    Hi i cant send a fax
    First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
    May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
    My handset doen't have a ring tone and cannot be used. Also, my machine won't pick up calls.
    Try unplugging power and re-plugging first.
    Plug a regular phone into the wall jack and listen for a dial tone.
    Make sure the phone line is plugged into the LINE port of the fax machine.
    What is make / model?
    Sep 26, 2008 | Panasonic Office Equipment & Supplies
    I have a d880 i cant receive faxes on it.
    Is it set to AUTO RECEIVE?
    Plug a regular phone into the wall oulet and listen for the dial tone.
    Make sure your phone cord is plugged into the LINE port of the fax machine.
    Sep 23, 2008 | Office Equipment & Supplies
    BT Freestyle 2200 do dial tone
    I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
    Are your phones getting charged?
    Try putting the base station into a different phone line/ socket if you have one.
    if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
    Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
    Phone has not dial tone or buttons have no function
    This is not a problem..You will need keep your phone plugged into the power jack and the powe switch must be on.Then connect the phone line..thats all the phone will register itself and start working..
    Oct 19, 2007 | Lands Phones
    Lands Phones Logo
    226 people viewed this question
    Top Vtech Lands Phones Experts
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
