Question about Cameras
Drop in water - Cameras
  • 659 Answers
Ok I had this happen to me short story simple it was a wedding and one guy was getting out of hand and I ended up in the pond.
ok this might not work but we will see..
gotta dry it out as much as possible do not do anything to it try to turn it on or anything
remove the batteries and any installed cards
find a nice warm spot for it.
use a blow dryer
I let mine dry for a day and nothing let it sit for a week in a really warm spot and it worked.
this might not work for you but if you have pictures on your camera then hopefully it will allow you to remove the pictures from your internal memory.
good luck and keep me posted.
Posted on Aug 12, 2008
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Oct 09, 2014 | Water Heaters
What will happen when you drop a banana in some water will it have the same effects as when u drop potassium in some water
Short answer, No.
The potassium in a banana is not in the same concentration nor is it purified.
It is similar to how karoseen come from crude oil. a match in the oil will simply go out. The karoseen on the other hand will burst into flames.
Jun 21, 2014 | Sony Cyber-Shot DSC-W570 Digital Camera
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
2005pontiac grand prix with water in the gas tank
Your best bet is to drop the tank and then dump out the water. Dropping the tank isn't that big of deal. Remove the filler hose and a couple vacuum hoses. Unplug the main fue pump harness. Remove the fuel lines. Support the tank with an appropriate jack. Remove the straps and drop the tank.
Feb 06, 2012 | 2005 Pontiac Grand Prix
I dropped my phone and it could not on now
Due to hazard some phones are not working. If you dropped in water try with this steps.
  • Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately.
  • If the phone will turn on, you can try to make a call to be sure it is working properly. If you put your water damaged cell phone back together and it won't turn on, it is likely that some water has gotten down inside the phone.
If dropped in floor, please bring it to service center for repair.
Jan 04, 2011 | Cell Phones
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Water pressure dropping
have you checked the saftety relief usually set at 30psi sometimes will stick open and if it piped to a drain you should look and see if there is water running into it. The only other thing is a leak in the system but usually will be noticable by water lying somewhere.
Jan 19, 2009 | Heating & Cooling
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
