Question about Gateway Computers & Internet
I have a gateway 200solo laptop and i am trying to use it but the screne keeps tellig me that it has keyboard failure
  • Gateway Master
  • 3,051 Answers
Do u have a waranty on this if so use it if not contact the gateway techsupport they wil be able to help you out regards mike
Posted on Aug 12, 2008
SOURCE:
How do I replace a keyboard on a Gateway NE522?
Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg
Replace Keyboard Gateway Laptop or
Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
5.November.2015
Nov 05, 2015 | Gateway Computers & Internet
My computer screne keeps going black.I shut it off
if still shows faded picture maybe the light bulb is about to go
or bad inverter
persumed its a ccfl panel
Sep 24, 2014 | Computers & Internet
My computer screne keeps going black.I shut it off then turn it back on,the screne comes back on then d sub appairs across the screne then it gos black again,,I have to keeps doing that until it stop...
You didn't mention what make and model you have - but this seems to be a graphics card issue. Many (HP laptops a few years ago in particular) developed "Cold" solder joints on the motherboard at the graphics card. When the computer heats up, the connection is lost, when it cools back down, the connection resumes. Usually requires a professional repair - either by attempting to "reflow" the solder, or replacing the motherboard in its entirety. Might be more cost effective to consider replacing the computer.
My Gateway m-7315u keyboard is not working correctly
Has there been a spill? May be a hardware failure? Try re-installing driver at: http://support.gateway.com/us/en/product/default.aspx?partNumber=M-7315u Are ALL the Windows and Gateway Updates installed? May be a "fix" in the Gateway drivers list.
Feb 04, 2013 | Gateway M-7315U Notebook
I try to repeatedly hit f10 with the alt key, i get the windows recovery screne and then it freezes
if the recovery option wont work it is better for you to use the recovery disk that comes with the machine so that you can go back to it original state
Thanks for using Fixya.
Jan 24, 2011 | Acer Gateway NV53A36u
Gateway laptop model M1634u continuous beeping on startup , able to boot to safemode and normal mode, but on windows log in , it has a long string of characters entered for the password, can clear it out...
Yes the keyboard is likely the issue. As silly as it sounds I would recommend strongly pressing all the keys on your keyboard repeatedly. Perhaps a few have become stuck. Otherwise contact your manufacturer or local technician. -Ravi Shanghavi
Aug 18, 2010 | Gateway M350 Notebook
My keys on my gateway laptop is not working right
Your keyboard has a "Numeric Pad" on/off button, in order to compress a full-sized keyboard (with its separate numeric-pad, on the right) into the smaller size of the laptop keyboard.
Press that on/off button, to resume "normal" operation of those keyboard characters that are "multi-labelled".
Jun 16, 2010 | Gateway MT3422 RTL Notebook
Left laptop on bed in morning screne would not appear
try reseating the battery but before your return the battery after romving it Press and hold down the power button for 5-10 seconds then return the batt and try turning system on if it boots that will be good but if not try reseating the Hard Drive from the system then try booting again ^_^
Possibly the fan is not spinning in your computer, but if the above still does not let the system boot into windows and nothing is on the screen and u hear high pitched noise most probably the Processor on your system is toast only thing that can cause a no post with a high pitched sound is your processor
Jun 04, 2010 | Compaq Presario 700 470024-192 Notebook
Gateway W34OuI keyboard jumps several words back when typing text in Word, URL, whatever. Do I need new keyboard?
I have had this happen to me try to keep your fingers a way from the touch pad.
See if this Helps any.
Jan 09, 2010 | Gateway MT3705 Notebook
Numbers and backspace on Gateway 7330GZ not working
You might check and clean the keyboard connection to the motherboard. However, usually this indicates keyboard failure. It's most likely that you're have to replace the keyboard.
Aug 21, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
16 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
