Question about Refrigerators
Fridgemaster mtrl 130 keeps icing up horrendously. what might the problem be?
  • 29 Answers
Sounds like a faulty thermostat,turn this down to its lowest setting possible if it doesnt turn off you will have a faulty stat,it can be checked with a container of ice and a multimeter,place the thermostat bulb or wire into the ice the thermostat should break circuit,do not try this unless you are somewhat mechanically or electrically minded if you do attempt this UNPLUG the supply voltage first
Posted on Aug 13, 2008
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
IS FRIDGEMASTER MODEL mtz55176ff SUITABLE FOR AN OUTBUILDING
If the building is weather-tight, you should have no problem. Extremes of heat or cold will dramatically effect operation, so consider insulating the building, if that is an option.
Feb 18, 2015 | Fridgemaster Refrigerators
How much clear space for Fridgemaster MUR49100?
enough clear space to allow air to circulate between and over items
Feb 16, 2015 | Fridgemaster MUR49100 White 100 l Mini...
Hi.My Name is dr.v.rusu and I have got my Fridgemaster MTRF242 silver,Refregerant:R600 a/52 g.The problems is that recently it stopped keep cool in the top compartiment,-but down freezer is in very go
Cold air from the freezer is used to cool the refrigerator section. There is an air passage between the freezer and the refrigerator. That passage is probably blocked by ice.
You will have to remove some covers inside to find and melt the ice.
Aug 27, 2014 | Refrigerators
Water/condesation collecting at the bottom of my fridge
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 09, 2009 | Refrigerators
Fridge not cooling
hi,
Issue seems with the relay switch of the compressor .Please get it checked by an expert.
Jul 06, 2009 | Refrigerators
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
492 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
