Question about Frigidaire Refrigerators
Kenmore Refrigerator 795 7730 9600 freezer drawer on bottom
The top drawer of my freezer fits into two small holes on the plastic glides. Over time, the holes have broken open and now my drawer will not stay in. Because the icemaker empties into the bin that sits in this drawer, I cannot use my icemaker. I use my freezer constantly. Is there a recall on this? This is obviously a design flaw.
Thanks,
Mamba
guly
  • 67 Answers
SOURCE: SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Posted on Sep 24, 2007
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 63 Answers
    SOURCE: is there a kenmore refrigerator recall?
    The 800 number is available at:
    www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
    Posted on May 30, 2009
    • 363 Answers
    SOURCE: ICEMAKER CONNECTION
    normally the water connection is at the bottom right rear. There should be a blue valve.
    Posted on Jul 22, 2009
    How do I move a three-door refrigerator?
    open the freezer all the way. remove all the baskets and there should be tabs you push in at the plastic glide covers in back that you have to press in. then the drawer comes out with the glides and rails
    May 05, 2015 | Refrigerators
    Water leaking inside my vegetable drawer
    Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
    Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
    Glide rails on kenmore bottom drawer freezer keep freezing up
    I suspect that you've got a leaky ice maker. Do you have clumps of ice in the bin, too? Many times, replacing the ice maker will solve the problem.
    Jul 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
    Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
    May 20, 2012 | GE Profile Arctica Stainless Steel Top...
    Kenmore refrigerator model # 596.75522400 bottom frizer. Frizer works ok but refrigeratot does no get cold.
    If the freezer is cold, it is probably the evaporator fan motor or the damper. The damper is the easiest to check.
    Inside the refrigerator compartment, top, center, back is a small plastic grill that snaps out of a larger plastic housing. Tug gently from the bottom edge. You should see a small damper door. If it is closed, push it open. If you feel a flow of air, the fan motor is good and the problem probably has something to do with the damper not opening. If you do not feel the flow of air, it is probably the evaporator fan motor.
    If it is likely the damper, you can prop it open to get the refrigerator compartment cold again until you can solve the damper problem. I have not had to solve this problem yet, so good luck.
    I've had problems with evaporator motors in every Kenmore appliance I've owned. So, it is probably the evaporator fan motor. The motor is just above the evaporator coils inside the freezer compartment.
    Lift out the baskets and lift off the drawer front. Remove the drawer slide mechanism buy depressing a single plastic clip on each side as you pull the slide forward.
    If you
    Oct 23, 2010 | Refrigerators
    Upper spray arm failure
    Easy to solve!
    (1) Remove the drawers to give yourself room to work
    (a) bottom drawer just comes right out -- but you knew that
    (b) Carefully unclip small plastic retainer caps at the ends of the metal "glides" for the top drawer. Then slide the caps out of the glides. Then remove the top drawer.
    (2) Unscrew the "gear-like" plastic fitting into whose hole you were sticking your finger when you felt that small cylindrical ring.
    (3) Now that you've got access to the ring, the solution is obvious -- use it to snap the upper arm back into the gear-like fitting. When you're done, the arm will rotate freely in the fitting.
    (4) Put everything back together and enjoy the fact that you didn't have to pay some yobbo $75 to come to your hous and do this for you!
    (HINT: When screwing the gear-like fitting back into place, use the old machinist's trick of pressing gently and screwing backwards until you feel a click. The threads will now be aligned for you to screw things together the right way. If you do not do this, you might experience frustration reattaching fitting -- since the piece it screws onto is spring loaded.)
    Dec 06, 2009 | Frigidaire PLD4555RFC Dishwasher
    I have Kenmore refrigerator,leaks water inside.
    Is there an ice maker in the freezer? If so, check all fittings, otherwise, this is condensation, which is VERY common & is actually expected, especially in summer months. There should be a small hole in the bottom, center, under the crisper drawers, make sure that it is not blocked up. The condesation (water) that builds up goes through that hole into a condensation drain pan & gets cooked off by a little boxy thing (golly I forget the correct term & my husband is a refrigeration tech) that warms up or simply evaporates in to the air. The water you see is NORMAL, but your drain may be plugged up, so go have a peek to make sure it's clear, if not, just clear it out & you'll be good to go. Good luck.
    Aug 29, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
    Refrigerator is leaking water into drawers and out on floor
    Your defrost drain is clogged . Remove the rear freezer panel and using a hair dryer , defrost the aluminum tray below the coils . When you see the drain hole , defrost it and use a small tube to insert and blow thru to remove any possible "gunk" . You may have to use a little hot water to help defrost the drain , but keep at it until you can blow thru it .
    Mar 21, 2009 | Kenmore 64522 Top Freezer Refrigerator
    Kenmore Elite bottom freezer drawer won't shut
    Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
    Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Bottom drawer does not properly close
    Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
    What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
    It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
    Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
    Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
    Refrigerators Logo
    136 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
