Question about Singer 3116 Simple
Singer-tension My machine is having a similar problem. The top thread looks fine while the under side is a complete mess and just pulls out. I have tried adjusting the tension over and over with no different results... do you have any other suggestions?
  • Anonymous Aug 14, 2008
    I have the same problem:(
    It's frustrating
  • greencat Jan 04, 2009
    I bought this machine 4 months and have yet to sew anything because of this exact problem. I just got frustrated and gave up..
  • 323 Answers
You seem to have a tension problem or a threading problem. Try the following: Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Aug 28, 2008
After sewing a few stitches, the machine gets jammed. the top stitch looks fine, but underneath there's a ton of thread all bunched up (top spool thread)
What you are seeing is called "bird's nesting." There are two main reasons for "bird's nesting."
The first one is the thread not between the tension disks. That allows the thread to be pulled from the spool instead of pulling the thread tight from underneath. Always make sure to always put up your presser foot before you thread the tension disks. I also check the thread after I finish to make sure the top thread has good tension on it before sewing.
The second reason is the thread is not being pulled by the take up lever. Make sure you see it being pulled by the take up lever before you start sewing. If not, rethread it.
Good luck.
Jan 02, 2016 | Singer 8280 Mechanical Sewing Machine
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
Sewing Machine Thread Bunching Up Here Why
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
Birds nest under the fabric big loops of thread top side looks good...
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
Sewing machine tension
try adjusting the top thread tension & see if that helps
Jun 29, 2012 | Singer Sewing Machines
My Singer 4562 looks fine on the top and the bottom is a complete mess...it looks like a bird's nest. I think it had to do with the tension but I can't figure out how to adjust this.
try these suggestions
1. change needle--flat side goes to the back of the machine
2.check the thread take up lever & see if the top thread stay on it or jumps off, that can make the birds nest you mentioned
3.top tension ususally is on 3 or 4
if you don't have a instruction manual follow these steps
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 4562 ) & click search
if search comes up with nothing then contact singer customer service
and ask them
Mar 02, 2012 | Singer Sewing Machines
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Thank you. My machine, I received as a Christmas gift. I am very happy getting a machine, but my problem has been with the threading. I have gone over the directions many times and still I am not...
Try this, totally rethread, now with the presser foot up, pull top thread, it should feed smoothly, now put the presser foot down, pull top thread, it should barely move. This should seat your thread in the tension discs. A new needle will not hurt, be sure that you insert it with the flat side facing away from you. Try your tension on 3 and see if that helps. Do Not Turn Your hand wheel away from you, always turn it towards you or you will mess up your timing. Use a magnifying glass on the diagrams if you need to, I know it makes it easier for me to see exactly what they are showing. Good luck.
Dec 26, 2010 | Singer HD-110 Mechanical Sewing Machine
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
Under side of fabric.... the thread is a mess
Remove the thread from the upper portion of the machine.
Place the presser foot in the up position.
Turn the handwheel so that the take-up lever is in the highest position.
Ensure that the upper tension dial/knob is set to 5.
Thread the machine all the way and through the needle.
With the presser foot still up, hold the thread from behind the needle and pull about a foot of thread through. It should pull through with very little resistance.
Now lower the presser foot, pull the thread and you should feel great resistance.
If so, now try to sew.
If not, there is a problem with the upper tensioner.
Jul 20, 2009 | Singer 3116 Simple
Im pretty sure i have my singer 5525 threaded right but i think the bobbin is wrong but when i try to sew the top looks fine but the bottom is a thread mess an the thread keeps breaking
angle the bottom might be a mess but it is the top thread that
you see balled up .Pull the top thread and make sure there is tension on it ,if not check the thread is between the discs and there is nothing else between them .if this is ok there is something stopping the top thread from being pulled back up
through the needle plate to form a good stitch,if you can turn by hand and watch where it is catching you might be able to solve it.
Aug 17, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 3116 Simple Logo
269 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
