Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
No power lights
This is a two drawer unit, the top drawer's lights don't turn on and the heat element remains on. Nothing will work. I unplugged it because the heat element won't turn off which means I can't use the lower unbit either. I have the unit without LCD, the kind that has a cusom panel
  • LBrooksco Sep 02, 2008
    Absolutely no power indicated at top or bottom drawers after moving to new location. Something simple to reset, I hope. Thanks for your help.
  • 27 Answers
This one could be tricky. Probably the controller has failed (leaving the heater on). The could also be other issues, I would seriously suggest calling a F&P service company for this one, Sorry
Posted on Sep 23, 2008
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a heating and air unit. the air conditioner works and the fan will work. but when i turn on the heater it will not ignite. i have checked the thermostat and it sends the signal to the unit to turn...
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 13, 2011 | Heating & Cooling
Have a Electrolux refrig. french doors and bottom mount. model ei23bc56iso Its shut off. The display in front at the dispencer says OFF at frezzer side and OFF at refrig side. No other displays or error ...
  1. Bottom Mount Refrigerator Ice Maker. When the bottom mount refrigerator is placed in Sabbath mode the ice maker will be automatically disabled. Please be aware however, that although you have entered the Sabbath mode, the icemaker will complete the cycle it had already initiated. The ice cube compartment will remain cold, and new ice cubes can then be made manually in the freezer section (using a standard ice cube tray) as needed for that Sabbath/Holiday.
  2. Sabbath Mode and the Perfect Temp Drawer (if equipped). The Perfect Temperature Drawer should be turned off for the Sabbath/Holidays. Before putting the refrigerator into the Sabbath mode, turn the Perfect Temp Drawer off by pressing the drawer on / off button. The display will show "OFF" and the drawer will turn off. Then enter the Sabbath mode function on the main refrigerator display. The drawer display will now not illuminate and the drawer will remain off until Sabbath mode is exited and the drawer is turned back on. The drawer can still be used as a non temperature controlled drawer in this mode.
  3. Press the display button few seconds and recheck.
---------- Check out thanks.
Aug 27, 2010 | Refrigerators
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Have old tappan speedwave 1000. buttons work but when you press start nothing work except the countdown on display
Unplug the unit for 15 minutes...plug the unit in and try again. If that doesn't work - take the back cover off and look for any blown fuses...should be obvious.
Mike...
Nov 29, 2009 | Tappan Microwave Ovens
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
4 Elements and Oven not working
If there was a power surge when the power went out or came back on, it could have fried the controller.
Jan 16, 2009 | Frigidaire Ovens
GE Profile cook top - four years old
unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
Dec 24, 2008 | GE 30 in. JP340 Electric Cooktop
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
63 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
