Question about Sewing Machines
Singer Touch and Sew 606 motor/drive shaft hardware diagram/list
I was given a Singer 626. It appears that some of the hardware on the top end (away from the motor) of the drive worm gear is missing some hardware. This allows the armature of the motor to be pushed upward. Is there an available blow up of the parts for this area of the machine so that I can check to see what is missing?
2 Suggested Answers
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
Bobbin latch on Singer Touch and Sew model 626 won't seat properly. Therefore plate covering bobbin case will not slide back into place.
Have you had the bobbin case out? If so, remove it again and replace carefully.Or contact manufacturer .
Apr 29, 2017 | Singer Sewing Machines
How to replace top vertical gear on a Singer 413?
Owner's Manual available on eBay, but you may be better with a Service Manual.
This show an Internet search for 413 diagrams:
Google
Mar 29, 2015 | Singer 4166 Sewing Machine
Threading a bobbin diagram
I LOVED these Touch and Sew machines! The bobbin is wound in place in the bobbin case; you just flip a lever on the left, and it will start to fill. However, you should download your instruction manual free from the Singer Sewing Machine site; it's pictured and discussed on page 7.
A heads up, though; those bobbins were available with a metal piece in the center and without; from the drawing it appears that yours takes the one without anything but a hole in the center. I owned BOTH types of machines at the same time once, and I had to be careful as to which bobbin I used in which machine.
Jun 17, 2014 | Singer Sewing Machines
How do you remove the hand wheel on a singer model #648 sewing machine
Sounds like you might have a broken gear in the transmission. Since the Touch and Sew series (aka Touch and Swear, Sew and Throw, etc.) are so touchy about adjustments, I'd probably take this one to a good sewing machine mechanic and let him/her do the heavy lifting on this.
Parts diagrams: http://parts.singerco.com/CPpartCharts/6_6999/648E3_648E6_648E7.pdf
More: http://www.tandtrepair.com/600TandSstuff.html
(Sorry, but this is the era when Singer suddenly veered into the weeds.)
May 22, 2014 | Sewing Machines
Touch sew 770
Are you raising the thread from the bobbin before starting to sew? Are you holding the ends of the bobbin and top thread behind the presser foot before starting to sew?
See also the mess I (deliberately) made in the last two pairs of photos here:
http://www.picturetrail.com/sfx/album/view/22521551
The Touch and Sew series of machines was commonly given nicknames like Touch and Swear and Sew and Throw and other less printable names by mechanics who had to repair them. The bobbin system is *very* touchy, and a bobbin that's just slightly chipped, cracked or otherwise not completely perfect will throw the whole machine into a tizzy.
Feb 05, 2014 | Singer Sewing Machines
Put top back on my Singer Golden Touch and Sew.
Make sure the faceplate is open and thge takup lever down, hook the hook shape spring over the spindle at a bit of an angle, lower the top and push it to the right.
Mar 07, 2010 | Sewing Machines
I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Mar 06, 2010 | Singer Sewing Machines
Replacing broken gears on Singer Touch & Sew Model 648
Remove the plastic faceplate from the front of the machine. There is a Singer logo button that you will have to pop out to release it, and then the lever nobs to get around to get it off. You can then access the allen screw on the top gear.
Remove all the set screws on both the top and bottom gears on the vertical shaft. Put them in a safe place.
The vertical shaft sits directly below the horizontal shaft, but there is some space between them and wiggle room to do the following. If the shaft does not slip down easily, use a small diameter rod or screwdriver to gently tap the vertical shaft downward until the top gear slips off the end. Remove the gear.
Mar 09, 2009 | Singer Sewing Machines
Bobbin filling on Singer 626
Aug 17, 2008 | Sewing Machines
Threading the bobbin
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
Jun 11, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
413 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
