Question about Canon imageRUNNER 5570 Copier
E O61-02 HAVING BLACK COPIES AND JAM BEFORE THE FUSER ALREADY REPLACED LASER UNIT AND DC CONTROLLER BUT HAVE THE SAME PROBLEM
  • 18 Answers
Pull out the primary corona. Clean it good and change the primary wire. If you still get the code, you might want to try another primary corona unit.
Posted on Aug 26, 2008
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
Tip
ERROR codes Canon 4835
Canon 4835 E000 Low fuser temperature E001 High fuser temperature E002 Low fuser temperature E003 Low fuser temperature E010 Drive E030 Counter E080 Color change board problems E081 Color horizontal motor problem E082 Color horizontal motor problem E083 Color problem in vertical direction E084 Color problem in vertical direction E085 Color problem in vertical direction E086 Color unit claw release problem E089 Color change incomplete E100 Laser problem E110 Laser motor problem E140 Laser unit E203 Scan drive problem E210 Lens not home or won't leave home E240 DC controller E401 Document feeder pick up motor E402 Document feeder belt motor E403 RADF feed motor E404 Document feeder motor E411 Document feeder sensor E500 Sorter to DC control interface problem E510 Stapler/sorter motor E530 Stapler swing motor E531 Stapler swing motor E540 Sorter bin motor E541 Sorter bin motor E710 DC controller
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4080
Canon 4080 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
on Jan 18, 2010 | Office Equipment & Supplies
Prints lines on copies. replaced photo conductor unit. didn't make a difference
if you already replace PCU still produce line on copy it could be fuser roller found at fusing unit. if black lines replace fuser unit or if available fuser roller much better but if white lines just clean laser unit. another problem may contribute might be deform frame of scanning section includes mirrors and alignment of lens unit this problem occur usually upon transport of the machine.
Dec 30, 2013 | Ricoh Aficio 1013 All-In-One Laser Printer
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
Tip
ERROR codes Canon 4050
Canon 4050 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
Have a canon c130.changed toner and still getting dark streaks on copies. Have cleaned all I could find inside still dark streaks
Try doing a "stop test." You would induce a jam before the paper reaches the fuser.
Just open a cover while printing and hopefully some image has been transferred to the paper. If the defect exists already then the laser unit, or document scanner may be causing it.
If that eliminates the dark streak, then obviously the fuser FG6-3720-000 should be changed.
Whit
Item, Inc
Aug 18, 2010 | Canon C130F Black and White Copier
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
E000007-0000
Hello Evank,
I will gladly help you understand what's going on, but I am afraid nothing short of service call will actually resolve your problem. First off, the error code you are getting will cause the copier to just suddenly STOP...... which indeed will cause you to wind up with a paper stoppage but not a true paper jam. I apologize for what is like a distinction without a difference,but i just wanted to give the benefit of as much information as possible.The error code you are getting refers a subsystem of the copier called the fuser, which is a high temperature high pressure area that is common to all copiers. Because of the potential danger of high temp and pressure, all copier manufacturers design their products to be VERY sensitive to monitoring all aspects of the fuser as they do not wish to burn your building down. (bad 4 marketing) The E000007 error code refers to the fusing system. The code basically means that the on board computer of the copier did not get the signal it requires telling it that the fuser was working properly. That in fact it was not turning at the same time /speed as the copier. There is a sensor on this "fusing unit" that detects this speed. Either the sensor is bad, the fusing unit is indeed not turning at the correct speed and therefore is defective, or the dc controller ( a circuit board on the machine that processes most inputs) is defective. Most likely its the fuser/fusing unit which indeed is a "unit" and if it needs to be replaced will include the sensor previously described. The fuser (Canon also refers to it as a fixing unit) is good for @150000 copies more or less according to Canon and that is one of those things that I would call "according to the manufacturer" promises.In short, after this long winded description, unless you are a well trained copier tech, you will need one. But at least I have given you enuff info that you won't get screwed by the "copier dude" . :-) Of course I "IS" one. LOL . Good luck and I hope this helps you at least a little. ...........SPINAL........
Apr 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error Code 000061-0001
Error code for 0061-0001
Main cause : The laser shutter is faulty. The laser unit is faulty. The potential measurement PCB is faulty. The DC controller PCB is faulty.
Mode of detection : 0001- As the result of potential control, the drum surface potential (VL2) of the white background is about 200 V (generating solid black images.)
Dec 14, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5570 Copier Logo
51 people viewed this question
old marine
old marine
