Question about Toshiba Tecra M3 Notebook
Reset BIOS Had a blue screen that prompted me to power up with F8 to change to safe mode. Wouldn't go into bios screen, now when I boot up, I get the initial Toshiba screen, followed by a monochrome garbage screen. How can I reset the Bios ? Any help much appreciated.
  • kevinpearce Aug 13, 2008
    Pyrhyc.
    Thanks heaps for your info.
    Finally got into the CMOS screen and went to safe mode.I did a system restore using date a few days before the problem showed up. This was sucessful, and all now OK.
    Thanks again for the brilliant and speedy service, much appreciated. Cheers for now, Kevin.
    Genius:
  • 2,028 Answers
This isn't a bios problem, this is an operating system problem, and most likely a hard drive problem. Do a system repair with your restore or operating system disc. If the repair doesn't take, the reformat the hard drive using a full NTFS format, not the quick format, and install a new operating system. If the drive will not format, or you have any issues during or after the format and install, then the hard drive has failed and will need replaced.
Posted on Aug 12, 2008
Reset cmos on N550j?
try software to reset your cmos password.
Mar 26, 2014 | ASUS Computers & Internet
I have forgot my laptop BIOS password so please tell how i do and how it will be reset
Compaq bios password removal
http://www.youtube.com/watch?v=fuASaocUP2Q
also
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt
Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter.
Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup.
Youll notice the password is gone.
If this fails try typing
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Aug 14, 2013 | Compaq Computers & Internet
I need to reset the samsung 900x bios password
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
o 70 2e
o 71 ff
and hit Enter. Finally type:
Quit
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Feb 11, 2013 | Samsung 900x Ultraportable Laptop...
Download killcmos for bios password reset
Step 1:
Enable VGA mode
Reboot
DEBUG
o 70 2e
o 71 ff
Quit
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Feb 10, 2013 | Computers & Internet
Bios password reset
You realize this is webcam section
Enable VGA mode
Reboot
DEBUG
o 70 2e
o 71 ff
Quit
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
Jan 23, 2013 | Sony Vaio All In One Vgc-ls1 Ls20e Ls32e...
Satellite C850D bios reset solution
Enable VGA mode
Reboot
DEBUG
o 70 2e
o 71 ff
Quit
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps. http://www.laptop-repair.info/toshiba_bios_password.html
Jan 15, 2013 | Toshiba Satellite C850D-BT2N11...
Bios password for dell inspiron 1000
Enable VGA mode
Reboot
DEBUG
o 70 2e
o 71 ff
Quit
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Dec 19, 2012 | Computers & Internet
My computer will not boot up, how can i enter safe mode r saft moder
does it turn on? do you see anything on the screen when u push the power button? to get to safe mode hold the f8 key on the keyboard when you get past the initial bios post screen.
Nov 24, 2011 | Computers & Internet
We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
(Use the arrow keys to highlight your choice.)
Repair Your Computer
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: View a list of system recovery tools you can use to repair
startup problems, run diagnostics, or restore your system.
ENTER=Choose ESC=Cancel
Mar 18, 2011 | Computers & Internet
How to start in safe mode?
While the computer is initially booting up, press F8 (repeatedly if necessary), you should be presented with a selection screen to boot into safe mode (various levels such as with or without networking) or to boot normally. The F8 key only works while the computer is going through the BIOS startup procedure.
Jan 03, 2011 | HP Pavilion a1719n (RQ403AA#ABA) PC...
Toshiba Tecra M3 Notebook Logo
214 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
