Dryers Logo
Posted on May 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Casablanca ceiling fan model p4m55h has worked fine for about 2 years. Now the remote will not operate fan or light. I have checked light switch wiring (all ok) replaced battery in remote, and checked light bulb. Could the problem be in the transmitter in the fan housing? H E L P ! ! ! Thanks
Shaun Eddy
Level 2:
Novelist:
  • Expert 147 Answers
  • Posted on May 09, 2011
Shaun Eddy
Expert
Level 2:
Novelist:
Answers
147
Questions
Helped
66941
Points
490
Hi, my name is Shaun. Welcome to FixYa. I have been an electrician for 6 years, and I have to say that your troubleshooting skills are impressive. Looks like you have covered all the bases. So, to answwer your question, the problem is most likely, yes, your reciever in the fan, unless the transmitter has been dropped or damaged in some way. Recievers rely on transitors to close the higher voltage circuits to turn on the lights and fan, and these tend to burn out occasionally. I believe you can buy wireless kits from Home Depot or Lowes that include both transmitter and reciever. In the meantime, you can rewire your fan and light to operate from the switch if you have pullchains or seperate switches for light/fan. If you do and you would like me to walk you through this process, reply to this answer. Hope this helps out. Have a good one!
Need a internal wiring diagram for a Casablanca Fan P4M55H
I don't think you can do that if it came with a built-in receiver.
1helpful
2answers
Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
Here's Casablanca Support phone number:
Call Toll Free: 1-888-227-2178
Hope this helps!
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
2answers
Remote stopped working, fan and light do not
click the reset and turn off the fuse box and then turn on
No remote control
I'm sure you can buy a new remote for that fan, but you will have to access the remote reciever in the fan itself so that you can get the switch sequence so that you can match it with the remote you purchased, it should work fine.
P.S. Dont tear the hell out of the package just in case you have to return the remote. I find the easiest way is to cut the plastic package close to the cardboard on three sides with a box cutter.
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
2helpful
My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with...
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
Fan won't go on
Possibly a bad receiver, contact Fan Man Lighting at 1-866-600-3267 and ask for Jason, he has 21 years experience with Casablanca
Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Top Dryers Experts
john h
