Question about Kenmore Elite HE4 Electric Dryer
Won't start, just beeps - sounds like door switch problem others have had
My light bulb burned out. It won';t start, just get 3 short beeps. I tried testing the thermal fuse as you sugessted (bypassing it) and no change. Could be the door switch. When I enter diagnostic mode, I don't get an 88 on the front panel as the paperwork indicates, I get a 4E (not flashing). Opening and closing the door does not make it beep (again, could be that switch). Any idea what the 4E indicates?
Our whirlpool duet (over 6 yrs old) stopped turning on after the light bulb blew. The control options still allowed us to choose a setting but blinked and beeped when we tried to press start. After researching online, we found that this is because the dryer thinks the door is open even though it was closed. Apparently when the light bulb blew it drew enough of a current to fuse the switch that senses door closure. My husband first checked the switch for continuity and it was fine (using a OHM meter). If you don't know how to do that, or don't have an OHM meter, you can just try what we did: After unplugging the dryer, my husband pulled the door switch out, disconnected the wire leading to the light bulb (in our case the tan wire) made sure the other wires were connected and pushed it back into place. We plugged it back in a voila...it works just fine. If the switch is bad, the part can be easily ordered through Searspartsdirect.com. It is part #8519323 (also known as part number 8283288). This comes with both the knob and the wiring. Was about $20 plus shipping.
Posted on Dec 21, 2011
  • pcz0925
    pcz0925 Mar 05, 2012
    My Kenmore HE4 (clone of WP Duet) exhibited the exact same symptoms - interior light bulb went out, exterior lights worked, pressing start button resulted in 3 beeps. Not being handy with electronics I skipped step 1 and went to step 2., I disconnected the wire from the door switch to the light bulb (same as yours - tan) and voila, mine now works fine too. Thanks for documenting your solution and saving me a lot of time, money, and aggravation.
Baseballcop9 wrote:
Thank you sooooo much for that info. The burned out bulb caused the current to fry the control panel console. Just spent 200 on a new control console ( which is the complete front panel). Installed it and pushed the button and three beeps, checked the door switch and still three beeps. Went into diagnostic and had the 4E code.
After reading you post about the bulb, I simply removed the factory bulb which was burned out, now the dryer works fine.
We had this dryer for 7 months when the bulb initially burned out. Couldn't figure out the problem so we kept the dryer thinking a solution would come up eventually. Sears refused to help us back when it initially broke down.
This info needs to be passed on to any owner of this model dryer.
Thanks again
Posted on Sep 15, 2011
My HE4 dryer failed in a similar manner. What happened is that when the light bulb blew it drew so much current it fused the switch that senses door closure. The repair man replaced the bulb and loosened/'un-stuck' the switch (did not replace it). I believe the beeps are that the dryer thinks the door is open, even when its is closed. The repair man said this was a common problem. He also said something about the factory bulb made this failure possible, replacement bulbs fail without drawing so much current.
Posted on Aug 19, 2008
  • Baseballcop9 Sep 15, 2011
    Thanks again
    Scholar:
  • 121 Answers
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Posted on Aug 16, 2008
Kenmore Dryer he4 won't start
Those fuses are put there for a reason and should never be bypassed. If something happens you have a short it could kill you or cause a fire and we would not like to see that happen. There has to be a reason for this fuse to blow and should not be bypassed. Sorry
Nov 11, 2014 | Kenmore 63932 Electric Dryer
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
Dryer won't run
Start from scratch, hook every thing back up, do not bypass the thermal fuses for your issue, all you are bypassing is the heater element.
Unplug the unit, check the breaker, then the cord for burning. then come back and will take you to the next step.
Dec 26, 2012 | Dryers
Horn doesn't work, revrese lights won't come on, and 2 of the 3 break lights won't come on on 1995 Geo Tracker. Fuses are good and bulbs are good.
for how long, 1 day, 1 year , 1 decade? is it a daily driver
or a barn stored, winter car.?
the real question,is there 12v exiting the fuse, the acid test. that.
any volt meter does that in 5min flat.
3rd brake light is bad bulb or corroded socket.
what tranny< 3,4,5,sp.? but in each case it takes a good rev.
switch, if 12v enters said switch and does not exit, its bad.
0v bad,6v rev. path shorted to ground,12v good.
btw, all clamps can short, try 1 new one. in each path all by lonesome. dig?
bulbs good means what.
1: look good.
2: glow when placed on a 12v battery
3:measure 0 ohms with meter (means good or shorted.
4: or they are new and assumed good, (p/n ? what is the p/n?)
head lamps good.? parking lamps, blinker, are all other lamps working. does car start?
Dec 05, 2012 | 1995 Geo Tracker
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
Brake lights won't turn off even with fuse out
the circuit is shorted to the bulbs somewhere in the wires there is a short causing power to bypass the fuse and constantly run to the bulbs
Aug 03, 2012 | 1989 Dodge Ram D-Series Pickups
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
2002 Isuzu axiom cluster lights and tail lights out
Don't try a higher fuse , it just makes things worse by adding extra burn to the problem.. First make a test lamp with a 21w bulb ( indicator size) .You now have a bulb with two wires attached , insert the "test bulb" across where the fuse should be.
When you switch on the circuit concerned it will glow BRIGHT as it is getting a POS (+) and a NEG (-) ie blowing the fuse (short circuit) in the fuse box and therefore a BRIGHT bulb.
As you disconnect and eliminate or disturb the problem the bulb will immediately glow DULL ( in series contact now) and no longer a short circuit . As you check the circuits the illumination will change and, your on the money ! Let's know how you get on , Good luck
Mar 05, 2010 | 2002 Isuzu Axiom
Tun signals and break light fuses keep burning out changed the bulbs and still same problem. fuses will work for 3 to 4 hours then burn out
theres a short in the circuit,trace the fuse circuit more often there is a line shorted to ground.it may also good to check the light bulb sockets to see if there is a shorted wire or contact.
Sep 09, 2009 | Chevrolet Impala Cars & Trucks
Kenmore Elite HE4 Electric Dryer Logo
471 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
