Try the official play doh site
http://www.hasbro.com/playdoh/
Even if the tip does work for you ... check out the site anyway they have tons of out to make items with playdoh
This is the tip they give you to re hydrate your playdoh
My PLAY-DOH compound is drying out. How can PLAY-DOH compound be softened or moistened?
To restore the softness to PLAY-DOH compound, try adding water one drop at a time and working it in to moisten the PLAY-DOH compound.
You can also try wrapping the PLAY-DOH compound in a damp paper towel, returning it to the container and replacing the cover. Let it sit overnight
Good Luck. RJ
Testimonial: "Thanks for the tip. That is exactly what I was looking for."
In most cases, you should add warm water on the food a wait around
five minutes and then you should drain the remaining water.
