" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
depending on the model, you could try pressing and holding the clear/off button for about three seconds. if you need an owners manual, you can try http://www.frigidaire.com/ .
No fault of the camera it's has been programed in custom function #9 for mirror lock up. In mirror kock up mode first click of the shutter button locks up the mirror the second takes the shot and lowers the mirror. Mirror lock up is most often used while tripod mounted for extreme close ups or macro photography and also where a large telephoto lens is used. Mirror lock up is for reducing camera vibration during exposure. You can go into your custom function menu scroll to #9 and turn this off and all will return to normal.
Did the unit have anything plugged into the blue two pin port? If so, trace that wire (black & gray) to the programming switch. Once you have located the switch, turn key on, press and release the button three times. The parking lights will flash once. Press the lock button on the new remote. Press and release the programming button once (two flashes), press unlock button. Press and release probramming button once( three flashes), press remote start button. Press and release programming button once (four flashes), press option button. Turn key off. test system.
When you reintilize the scanner, it should lose all programming and settings. Hold down the Tune/Clear button while pushing the reset button. Do not release the Tune/Clear button until the display clears and returns.
I
conclude that this dorr lock is better that is appear. Is not a 2 codes
door lock, it's a 3 codes one.. and the problem you have is the third
code not reset. You can put the same code in each third emplacement. you
have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
To program the first code, press the reset button once, then enter your 4-8
digit code on the exterior keypad, then immediately press the middle
lock button on the exterior keypad. You will hear a beep. This signals
that your code has been accepted.
To program the second code, press the reset button twice , then enter your 4-8
To program the third code, press the reset button 3 time, then enter your 4-8
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
