Question about Toshiba Magnia SG30 (SYU3882W-00001) Web Server
Cant locate server
We have a signal, but the server can not be found on not of the computers except this one,
Tip
Windows Server 2008 Network Driver for Proliant ML350 G3
Anyone who has tried loading Windows Server 2008 on their Proliant ML350 G3 has found that HP does not offer the network driver for this system.
BUT, the Windows Server 2003 driver for the NC series Broadcom 1gb will work! Rather than choosing the 'install' option, choose to 'extract' it, then via the device manager, manually install the driver from that location.
Happy Computing!
on Feb 04, 2009 | HP Compaq ProLiant ML350 G3 Server
Server not found wireless
This may be a signal strength issue. It may be necessary to install and extension cable for the antenna, or a signal booster midway between the wireless access point and the computer, or maybe both.
It all depends on how far away the computer is from the access point, and how many walls it has to pass thru. The thickness of the walls changes if the walls to deal with are at an angle to the computer or perpendicular (90 degrees). This makes the wall thicker if it is at angles between the PC and the wireless access point.
If at all possible, moving the wireless router closer to the PC, will help, as will moving the PC closer to the wireless router. This solution will solve the problem without much added cost. Also, moving the PC is probably easier, because it IS wireless. If this is unacceptable because of location, or surrounding shelves, etc., then a wireless repeater will be necessary. YOu will need to get help from someone who understands wireless installations, as it can be tricky in some instances to place it where it will do the most good. It may cost $100 or more for this device.
Oct 05, 2013 | TP-LINK Computers & Internet
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
In July 2005 we bought a Dell Dimension 3000 office computer and right from the start we could not connect to the internet or our network. Dell offered no help and just said "reinstall Windows"! Finally,...
Sorry about that here is what you need to read.....
You can set the NIC to On (default), Off, or On w/ PXE. When the On w/ PXE setting is active (available only for the future boot process), the computer prompts the user to press <Ctrl><Alt><b>. Pressing this key combination causes a menu to display that allows you to select a method for booting from a network server. If a boot routine is not available from the network server, the computer attempts to boot from the next device in the boot sequence list.
Mar 31, 2010 | Computers & Internet
Cant seem 2 b getn the drivers 4 xp got a ml110 any gud sytz!!!
HP build the proliant range of servers to support server OS's like Windows Server 2003/2008 and Linux etc. HP do not support any drivers for these servers for Client OS like Windows XP. You are best to locate the base chipsets and locate the generic drivers on the OEM sites for the chipsets. HP is unlikely to post drivers on their site except for emerging server OS's and Current server OS's.
As you do not list which version of the ML110 nor which Generation, I can't point you in the correct dirrection.
Thanks
Feb 02, 2010 | HP ProLiant ML110 Server
Using 1000SW, I get report of:- Connection Status DSL Signal: DSL found on Line 1 PPP Login: Login successful Internet Address: An Internet address was verified ISP Link: Domain Name Server...
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
spin
Sep 04, 2009 | 2wire HomePortal 1000 Router
I cant open youtube
Go to Start > Control Panel > Windows Firewall> Exceptions> Click on add port.
Call it port 80.
In port number type in 80.
Then click on OK.
Then close all the windows.
Basically on the computer that is running apache (Server), YouTube is unblocking the port called 80. On some systems mainly XP home we found that port 80 was always blocked. Even though localhost worked, computers connecting to it would get an connection error. Also, if you have a 3rd party firewall, you have to unblock YouTube. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
Canot dispaly web page
do you have a proxy server configured in you IE?
tools, options, connections, lan connections. Is the option Proxy server enabled and configured? If so please disable and try again.
Oct 27, 2008 | Computers & Internet
High Ping When playing Battlefield 2142 Online
There are a lot of factors that can affect ping rates. Server location, server load, local internet load, and your computer and network setup. The server you access for Battlefield may be too far from you. Try typing "ping 69.147.114.210", at the command prompt,(usually found in "All Programs/Accessories") also without the quotes. You should get numbers in the 40-60ms range. (thats Yahoo.com by the way), then put in the IP number of the Battlefield server. Any returned numbers under 100ms are ok, if your getting higher numbers, check the Battlefield forums to see if there is a server closer to where your located. If your getting numbers over 250-300ms at both sites, then download Lavasofts Adaware SE which is free, and Spybot Search & Destroy, also free and run them both, (once a week after as well) they will remove spyware and adware from your computer. There is a possibility that spyware or adware is using network resources.
Aug 11, 2007 | ASUS V8420/TD Graphic Card
Toshiba Magnia SG30 (SYU3882W-00001) Web Server Logo
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
