Question about Vacuums
Hoover all terrain dual v spin and scrub 12 amps
I used the cleaner on the coach the other day. Now the brushes will do not work when I wash the rug, it is on the correct setting. The cleaner has three setting spill, hard surface, rugs. I have some # not all it is a Hoover steam vac all terrain dual v auto rinse spin scrub mode 12 amps, series Z12.0 model F??52-980, SS#020700001449 someone HELP HELP THANK YOU FOR ANY HELP.
Thanks for your help I will try that . thanks again
Posted on Aug 28, 2008
  • 24 Answers
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Posted on Aug 12, 2008
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
My brushes on my hoover steamvac all terrain carpet and hard floor cleaner will not spin what do i do
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
Hoover F7XXX Link
http://www.usavacuum.com/Hoover-Steamvac-s/107.htm
Jan 29, 2010 | Hoover STEAMVAC VACUUM Vacuum
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Instructions
how do i properly use hoover steam vac clean surge 12 amp.
Aug 16, 2008 | Vacuums
Hoover terrain steam cleaner, brushes wont spin
The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
324 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
