Question about Nikon COOLPIX L18 Digital Camera
Nikon coolpix s10 lens error - Nikon COOLPIX L18 Digital Camera
  • foneni Oct 16, 2008
    when i switch on camera lens error message comes on
  • 315 Answers
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Posted on Jul 19, 2009
  • mithun dey
    mithun dey Jul 19, 2009
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
  • BARKHA JAIN Jun 05, 2011
    I AM FROM BANGALORE INDIA, IGOT MY NIKON S10 CAMERA FIXED AT MATA ELECTRONICS, NO 86, SP RD.OPP TO VIVEK COMPLEX BANGALORE 2 . CONTACT MR VIJAY FOR LENS ERROR AND ALL PROBLEMS. CONTACT 9035871324. THANK U MR VIJAY.
  • 11967 Answers
SOURCE: Nikon coolpix s202 shows lens error
Fixing a Lens Error on a Digital Camera
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Posted on Mar 28, 2010
  • 11967 Answers
SOURCE: I drop the Nikon coolpix S10 on the floor and it
Posted on Jan 11, 2010
Testimonial: "My Nikon coolpix S10 was firstly can took photos sometime and sometime showing lens error. But now it show only lens error every time I start on "
jackboy
  • 2985 Answers
SOURCE: nikon coolpix p2 lens error
Lens error = Lens damage
The opening closing mechanism has failed because of dirt ingress or damaged caused by a knock
or early failure in a young camera.
If it is still under warranty take it back to the seller for replacement.
Be aware - there is no repair option the makes economic sense.
Posted on Aug 21, 2008
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Posted on Mar 29, 2010
  • 1382 Answers
SOURCE: Nikon Coolpix touchscrren says
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 19, 2010
Lens error message(nikon l16)
I was having a "Lens Error" with my Nikon Coolpix S10 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good Luck!
Sep 27, 2009 | Cameras
''Lens Error'' with Nikon Coolpix S10
Turn the Coolpix S10 on using the button to the left of the 'OK' rocker which has a picture of a camera and an arrow beside it. You may need to hold this button in for several seconds before it responds.
The camera should turn on in the mode used to view stored photos, and this may bypass the lens error message. Pressing the button again can get the camera to switch to picture taking mode. This worked on my S10 after I dropped it. Hope it works for you! regards Thomas Mann
Jul 19, 2009 | Cameras
Nikon coolpix s10 problem lens error.
Your camera lens is bad. Sorry to say this is a repair not worth the price.
Jul 03, 2009 | Nikon COOLPIX S10 Digital Camera
Lens error on nikon coolpix s10
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 06, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon coolpix s10, Lens error
This is a pretty common problem, especially on the coolpix range of cameras. Basically it means the lens has had some issue while driving in or out of the camera body, in some cases a simple tap on the camera side(not recommended by me) can fix the problem, in others you will have to send the camera to nikon to fix it but it will fall outside of warranty as its not considered a normal camera error.
Oct 31, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix S10 Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 04, 2008 | Nikon COOLPIX S10 Digital Camera
Lens error in coolpix s 10
Aug 15, 2008 | Nikon COOLPIX S10 Digital Camera
Nikon coolpix s10 vr lens error on display and camera wont turn off
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 09, 2008 | Nikon COOLPIX L18 Digital Camera
Lens Error
Could be fatal - looks like it need to go to hospital- Nikon support Looks like CoolPix dont like that sort of Cool huh
Mar 08, 2007 | Nikon Coolpix S4 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
4,187 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
